Another, first HDR attempt
Discussion in 'HDR Discussions' started by Foxman, Apr 9, 2010.
  1. Foxman
    Foxman TPF Noob!
    Dec 11, 2009
    194
    North Carolina
    [​IMG]
    This is two shots using photo merge in PS Elements
  2. Bynx
    Bynx No longer a newbie, moving up!
    Feb 8, 2008
    2,804
    366
    Just outside Toronto Canada
    The foreground parking lot looks good as well as the sky. But the pic isnt large enough to see any detail in the shadow areas. The idea of HDR is to show both shadow and highlight.
  3. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    Bynx with all of tips in different post you outa right a book it would be a best seller;)
  4. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    2 exposures is really not enough for an HDR... you should be doing like 5-7. You don't have a lot of dynamic range in this shot.
  5. Bynx
    Feb 8, 2008
    2,804
    366
    No matter how many posts I write, Im still lagging behind you trying to catch up. By the way I think the HDR forum is pretty slow. Not much action of input or output going on here. Im mainly interested in HDR both in helping others and getting better myself.
  6. Ifocus4u
    Ifocus4u TPF Noob!
    Apr 12, 2010
    54
    For your first attempt I must say this is very well done. This type of shot needs subtlety which you did successfully. My only suggestion would be to take it into Photoshop...if you use it .. and lighten up the homes since they are quite dark. I often take my HDR work back to the "Shop" to tighten up the tones .. etc... Good work!!;)
  7. stevegonsalves
    stevegonsalves TPF Noob!
    Apr 21, 2010
    9
    ny
    This is my result for your pic. :hug::
    [​IMG]
  8. DaveAllen
    DaveAllen TPF Noob!
    Feb 13, 2010
    13
    Asheville, NC
    Nice job Foxman! Try bracketing 3 or more exposures next time...
  9. Bynx
    Feb 8, 2008
    2,804
    366
    Not bad Steve. HDR Darkroom works pretty good it seems.
  10. gregg_UCT
    gregg_UCT TPF Noob!
    Apr 20, 2010
    25
    San Francisco
  11. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Greg
    What would make me, or anyone spend the money on your product, when we already have another product? Especially since your product seems to be the most expensive one I have seen.
    ...this question is real, not meant to be a snyde remark.
  12. gregg_UCT
    gregg_UCT TPF Noob!
    Apr 20, 2010
    25
    San Francisco
    Pierre, hi.
    Good question. I guess the answer is that not all HDR software is created equal. Different applications will produce different results. If you are absolutely thrilled with the solution you are currently using, then there really isn't a good reason for you to buy anything else.
    HDR PhotoStudio employs a proprietary 32-bit HDR ColorSpace that produces natural looking "True Color HDR" images. It is also the only major application that allows you to perform all your color and tonal edits on the full 32-bit data. It is a different tool in your tool box that produces different results. Many photographers carry a point and shoot camera as well as a DSLR and decide which tool to use based on the particular task.
    In any case, I was only suggesting that you take the free trial version for a test drive and see how you like it compared to your other tools.
    Hope this helps.
    Gregg
