Another one of my niece
Discussion in 'People Photography' started by Sontizzle, Aug 30, 2008.
  1. Sontizzle
    Sontizzle TPF Noob!
    Jan 13, 2008
    233
    Kentucky
    had this one for awhile and just now decided to do something with it. only editing done was a few color corrections and cropping. theres a few shadows im not too happy about but im still trying to get the hang of these strobes. also i wish my sister would of dressed her more appropriate for the shoot. C&C!
    [​IMG]
  2. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,039
    80
    Kankakee, IL
    Well... I think you identified the biggest concerns. The lighting scheme isn't far off and might be best handled by the way you pose the subject in the lighting. Turning her face away from the main light creates a broad lit scheme.
    The shadows are a bit defined (sharp edges). Presuming you used umbrellas (?), try moving the light in close, making them less directional.
    You do need to add a background light to afford separation of the subject from the background.
    As for the clothing... I think this might have worked out OK, but you have her "out of key." Since she is dress in all white or light tones, shooting on a white or light background is one solution. In other words, with high key clothing, use a high key background.
    I hope this helps.
    -Pete
  3. Sontizzle
    Sontizzle TPF Noob!
    Jan 13, 2008
    233
    Kentucky
    didnt use any umbrellas, had 2 soft boxes at a 45* angle
  4. kellylindseyphotography
    kellylindseyphotography TPF Noob!
    Mar 26, 2008
    1,270
    Haverhill, Ma
    Its a cute little girl but does nothing for me beyond that. The comp is sort of blah, centered, and the lighting isn't anything special either.
  5. Christie Photo
    Jan 7, 2005
    7,039
    80
    Kankakee, IL
    Are they quite a bit back from the subject?
    -Pete
  6. Sontizzle
    Sontizzle TPF Noob!
    Jan 13, 2008
    233
    Kentucky
    probably about 6 or 7 feet away, maybe a little more.
  7. Christie Photo
    Jan 7, 2005
    7,039
    80
    Kankakee, IL
    OK... I suggest you put one (fill light) near the camera and the other (main light) in closer, keeping your angle, about 3-4 feet from your sujbect... just out of view.
    I think you'll like the results.
    -Pete
  8. Sontizzle
    Sontizzle TPF Noob!
    Jan 13, 2008
    233
    Kentucky
    i have a smaller fill flash strobe with a gold umbrella i could of set up in front of the subject. gives off good color for skin tones IMO. should of used it :(
  9. Christie Photo
    Jan 7, 2005
    7,039
    80
    Kankakee, IL
    Maybe not. Before adding a light source with a differing color temperature, consider how you're using these two.
    Think of it like this: When making a photograph, we record reflected (or transmitted) light. So it would follow... no light, no record.
    The next thing to remember is that a portrait is a two-dimensional representation of a three-dimensional subject. The first way to commicate shape is with shadow and highlight. Since we need to light everything to achieve a record, a good starting point is to achieve a 3:1 ratio between the highlights and shadows.
    The role of the fill light is to light the shadow areas of the portrait. Place the fill light close to the camera so that it affords flat, nearly shadowless results... illuminating the entire scene. Now, eveything has been blanketed with ONE UNIT of light. That takes care of recording detail in the shadows.
    Now to add the highlights. That's the job of the main light (also called the key light). The job of a softbox is to make a small light source into a larger light source, diffusing and scattering the light. We get the most benifit of a softbox when it is placed close to the subject, keeping it relationally large in comparison to the subject. For a conventional portrait, it should be positioned above and to one side of the subject. In order to achieve a 3:1 ratio, this light should be powered to add twice the level of light on the subject that we already have from the fill light. In other words, the main light is giving off TWO UNITS of light. So.... if we already have one unit of light on the entire subject, adding two units on some of the areas gives us a total of three units in the highlights and one in the shadows.... a 3:1 lighting ratio.
    Now we can add other lights to enhance the portrait. A background light will communicate seperation of the subject from the background. Remember: no light, no record. So if no light is falling on the background, we get black.
    SO.... before adding lights, consider if the first two lights are doing thier job.
    I hope this helps.
    -Pete
