Another SB600 ?
Discussion in 'Photography Beginners' Forum' started by tmagee, Dec 13, 2007.
  1. tmagee
    tmagee TPF Noob!
    Nov 21, 2007
    23
    Yarmouth, ME
    I've read many of the other threads about setting up the CLS but I have one quick question. I have a D80 and I want to use my SB600 off camera but I don't want to use an on-camera flash to command the SB600. What are my options so that only the off-camera flash (SB600) fires? Thanks.
  2. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,699
    68
    Missouri
    Don't use the built in wireless, use external triggers.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    depends, I've never had any communication problems with CLS, than again, I try to always keep my SB-600 in direct line-of-sight with my D70.
  4. sabbath999
    Apr 11, 2007
    2,699
    68
    Missouri
    Hrmm, I read that totally wrong, I thought he was saying that he didn't want the on-camera flash to fire... (i.e. the pop up flash). I was thinking he meant that he didn't want it pre-flashing like the iTTL does to determine exposure, I have no idea why that popped into my head.
    You certainly can use the SB600 with the built in camera commander just fine, I do it all the time and have not had problems...
  5. tmagee
    tmagee TPF Noob!
    Nov 21, 2007
    23
    Yarmouth, ME
    could you clarify for me how external triggers work.
  6. sabbath999
    Apr 11, 2007
    2,699
    68
    Missouri
    Sure, you plug one into your hot shoe, put one on your flash, and you shoot the picture.
    However, you do have to use manual exposure when you use them, instead of just relying on your camera meter as you would using the Nikon wireless.
  7. tmagee
    tmagee TPF Noob!
    Nov 21, 2007
    23
    Yarmouth, ME
    to clarify, I don't want the on-camera (pop-flash) to fire. I'm using the SB600 off-camera and I want that to be the only one that goes off. Thanks
  8. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    pocket wizards, IR triggers, a pc cord, or an off camera hotshoe cord will all work..
  9. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    yep, but those cost money for the same results and no TTL metering.
    I do location portraits with CLS and i've never had anyone blink from the commander flashes off my D70.
    You can buy an SU-800 which keeps all that and doesn't use visible light to command units, but again it costs money as opposed to a system that's free with the strobe and works 100% of the time within it's very reasonable limits.
  10. Mike_E
    Jan 26, 2007
    5,327
    265
  11. tmagee
    tmagee TPF Noob!
    Nov 21, 2007
    23
    Yarmouth, ME
    thanks everyone for taking the time to post.
    Sw1tchFX - I'm not too worried about people blinking from the command flash. If you look at sabbath999's profile picture... thats what i kind of want to do with some of my subjects and objects. In that picture if the on-camera flash would have fired I think it would have lit up his whole face. I want to try just having the light coming from one direction (ie. sides & underneath). thank you again everyone.
  12. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    In the Commander menu, if you set the Built-In mode to (--), it will only send a pre-flash signal to fire the SB-600 and will not contribute to lighting the scene.
