Another simple question -- Using Flash
Discussion in 'Photography Beginners' Forum' started by echoyjeff222, Aug 15, 2010.
  1. echoyjeff222
    echoyjeff222 No longer a newbie, moving up!
    Jun 27, 2010
    633
    130
    WA
    I know all the basics about flash, but I'm still not sure about when I'm supposed to use it. I heard that you're NOT supposed to use flash indoors and you're supposed to use it outdoors? How about indoors when taking pictures of people? I'm confused! Thanks for any help!
  2. timlair
    timlair TPF Noob!
    Aug 14, 2010
    225
    Kansas City
    I know its good to use outside to fill in the shadows made by the sun. But only after you lower the power a few stops.
  3. LearnMyShot
    LearnMyShot TPF Noob!
    Jan 8, 2010
    171
    USA
  4. 786soul
    786soul TPF Noob!
    Aug 13, 2010
    260
    5
    Toronto, Canada
    I wouldn't say anything is SUPPOSED to be done or not. It's up to the discretion of the photographer. Example: If taking photos of a party in a night club, yes you're going to need the flash. How you use it is what makes the photos worth looking at or not. Bouncing the flash off of walls, using diffusers etc etc are all ways to reduce the harsh shadows a flash may give off while still lighting the subject.
    Using the flash outdoors to fill in areas where detail is lost is the most common use of the flash outdoors. When shooting into the sun, using a flash as a fill light to capture detail in a person/subjects face is common.
  5. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,966
    14
    Durham, UK
    Flash is a photographers tool, if you need to shoot and there's too little light use flash as its a controllable light source. H
  6. white
    white TPF Noob!
    Mar 7, 2010
    1,131
    7
    Bad way of thinking. Creativity has no rules. But to answer your question, using flash indoors and bouncing it off the ceiling is a very common way to create diffuse light. Flash can also be used directly to flatten out the subject for artistic purposes. Just keep in mind that bounce flash is generally worthless in places with high ceilings, etc. Pretty obvious, really.
  7. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    The basics of flash is to know when and how to use it. So therefore, I'd think you may not know the basics.
    It all depends on the effect you're going for. For example........
    Flash Indoors
    (remember, you're not supposed to use indoors)​
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Flash Outdoors
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    and just to throw a spanner in the works........​
    Flash Outside / Subject Inside
    [​IMG]
    [​IMG]
    Like I said...... it all depends on the effect you want.​
  8. sleist
    sleist Been spending a lot of time on here!
    Nov 8, 2009
    3,610
    1,850
    Boston
    I like this shot.
    Damn, now I want a cigarette ...
