Another strobe question
Discussion in 'Photography Beginners' Forum' started by tjones8611, Jul 6, 2010.
  1. tjones8611
    tjones8611 TPF Noob!
    Sep 28, 2009
    230
    Chattanooga, TN
    In a couple of days, I will be doing a studio session and need some advice with the positioning of strobes. Part of the session will include some nudes/implied on a couch. The couch will be against a dark wall.
    Where should I position the lights for poses stretching across the couch? I have a large softbox and a couple of hot lights to work with. I would typically have one of the hot lights somewhere behind the model, but in this situation it is not practical. I can move the couch away from the wall, but not sure that would be beneficial.
    Any advice would be appreciated.
    scott
  2. KmH
    Apr 9, 2009
    40,343
    5,508
    Iowa
    That depends on the lighting effect you want to create and the specific pose the model is in on the couch.
  3. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,139
    2,936
    Chesterfield UK
    Move the couch away from the wall about 4 feet, one light behind couch low shining up the wall another light with a snoot shining down the length of her body creating an outline, the light behind will give a bit of seperation and hopefully show the couch up a touch, if set right should give a nice low key implied nude
  4. tjones8611
    Sep 28, 2009
    230
    Chattanooga, TN
    Thanks Gary, def will try. Any other ideas? I intend to try several different positions while there, but was hoping to get some general ideas before hand.
  5. flyingember
    flyingember TPF Noob!
    Mar 31, 2010
    318
    Kansas City, MO
  6. WhiteSoul8
    WhiteSoul8 TPF Noob!
    Jul 5, 2010
    15
    USA
    Look for a setting on the strobes for a "modeling light". This is basically a lamp that turns on full time, so that - in a dark room - you can see what your lighting, and where you are casting shadows.
    If you have the modeling lamps, which most strobes do, then it's just a matter of positioning the lamps and setting your exposure =)
    It's kinda like painting ...... lol
  7. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Start with a 3-point setup and then play around from there.
