any tips for graduated ND filter use?
Discussion in 'Photography Beginners' Forum' started by skywalkerbeth, Feb 14, 2008.
  1. skywalkerbeth
    skywalkerbeth TPF Noob!
    Nov 27, 2007
    101
    I am buying the Cokin set tonight - and a 2-stop ND filter - soft edge I think.
    Any tips and tricks for how to use them - I heard they are very hard to see the "line" while focusing...
    thanks for humoring all my questions!
  2. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    just depends really, like how much sky is in the particular shot... just slide it up and down until you get most the lighter area covered.
    If you end up getting any others (i have ND4 and ND8) its sometimes good to 'stagger' them so that the gradient is smoother.... so in other words put one higher than the other. Just play with them bit its quite simple to see how they work... and the ND2 gradient shouldn't be too strong anyway.
  3. skywalkerbeth
    Nov 27, 2007
    101
    Will two be strong enough to make a difference? thank you for the info...
  4. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    yea you will see the difference with an ND2, in the right circumstances... you wont be able to block too much bright direct light or anything.... but if the sun is to the side or behind you, you should be able to get a nicer exposure of forground and background elements.
  5. skywalkerbeth
    Nov 27, 2007
    101
  6. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    Looks good! Although just a suggestion, it looks like you might have needed to turn the contrast down a notch or two. Looks a bit on the harsh side with a lot of white from the clouds and then black in the brush. Was that a 2-stop grad ND? Usually that works pretty good for daytime shooting, but I find that I could use a 3 or even a 4-stop grad ND for sunrise/sunset photos.
  7. skywalkerbeth
    Nov 27, 2007
    101
    Thank you! Yes, 2 stops. I just hand-held it, on the fly.. I was shooting and then thought, hey, it might be a good time to pull that puppy out.
