Anybody use medium format (120) film?
Discussion in 'Film Discussion and Q & A' started by coolbeansxxBOOM, Nov 25, 2008.
  1. coolbeansxxBOOM
    coolbeansxxBOOM TPF Noob!
    Nov 24, 2008
    8
    I recently got the LOMO Holga camera, and while I've been using 35mm in it most of the time, I really want to try out the 120 film I have for it.
    The problem is, that I don't know how to develop it or where to get it developed.
    I develop my own black and white negative 35mm film, and although this may be a stupid question, can I develop the medium format b/w neg film the same way with the same chemicals?
    Or, can anybody recommend a good (preferably cheap) company to send/take the film to?
    -Michelle
  2. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Yes. Just make sure you have a reel that accepts 120 film and practice loading with a wasted film. Some people (including me) find it a bit harder to load 120 compared to 35mm film. Also the development times are sometimes different between 35mm and 120 film. Check the manufacturer data sheets
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    strange as it seems , loading 120 seems to be eaiser with steel reels than plastic. Most of my students have serious issues with 35mm film and ss reels, and are at ease with 35mm on plastic; however the reverse seems to work with 120.
    Steph has given you good advice. the only addition would be , be sure you have some negative sleeves for the 120 as well.
    doing your own is certainly much cheaper, is not hard and some of even love doing so :)
  4. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    The following links might help in your quest to develop MF at home:
    CLICK
    CLICK
    CLICK
    It's not hard to load the 120 on the reels, just that it takes a wee of practice in the dark. As suggested above, try it with a wasted 120 film, at first in plain light, then in the dark.
    Good luck.
  5. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    It's not so strange where I'm concerned. Loading 120 on ss reels were always a snap to me whereas 35mm would give me fits, and I had to expect the first five frames to be a waste. A friend of mine loaned me a 35mm reel that worked perfectly every time, but then he took it back, the bastid.:grumpy:
  6. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    Sounds like she has the goods. Just needs to make sure she has a 120 reel. Or at least an adjustable. Same chems and times comparing like to like.
  7. Dick Sanders
    Dick Sanders TPF Noob!
    Sep 7, 2008
    222
    Southern California Desert
    I shoot Ilford Delta Pro 100 and 400 exclusively. I've found that the best developer is Kodak xTol, diluted 1:1. Steel reels is the way to go. You just need to pinch the edges to make the film slightly concave and it'll roll around fine. Years ago, Fred Picker's Zone VI company made a 120 film guide device that attached to the reels that would guide the film without fail. Calumet bought that company, but they don't make the item anymore, but it's the kind of thing you might find out there. I still have mine and they work great. As a general rule, the thicker 400 speed film is easier to load without the dreaded crinkling.
  8. Patrick12345
    Patrick12345 TPF Noob!
    Jan 19, 2009
    If you don't want to do it yourself you could try "The Whole Picture Online" they offer free postage and a free cd with standard size prints, it works out at 9 quid for colour or 11 quid for black and white!
    Amazing service
  9. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    I always found it easier to load 120 than 35mm. Of course, maybe they were just better reels.
