anyone have a darkroom?:?
Discussion in 'The Darkroom' started by Rockgurl, Nov 27, 2003.
  1. Rockgurl
    Rockgurl TPF Noob!
    Nov 27, 2003
    I'm thinking about building a darkroom in a closet in my living room, right next to my bathroom (bathroom being my source of running water). I already found a place to buy an enlarger,printwasher,safelight,trays,tongs,paper safe, timer, measuring tanks, easels, developing tank, and cutting bord, for a resonable price. The problem I'm having is that I need somewhere to get paper, and chemicals. I also need to know exactly what chemicals I need, I know the general names of the ones I need, developer, stop-bath, fixer and photo flo, but I don't know the specifics. Does anyone know about the chemicals I would need? Does anyone that has a darkroom think it would be a bad idea to put the darkroom in the closet, or would it be completely necessary to have running water in the darkroom? Anyone that knows about darkrooms, please reply and give me any other tips and etc. Thanx...
    [​IMG]
  2. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    Running water is convenient, but not necessary. You need running water to mix the chemistry and to wash your film and prints. Both of these tasks can be done in the light so you can do them at the kitchen or bathroom sink.
    For developing film you only need total darkness until you get the film on the reels and into the light proof developing tank.
    For printing you will need enough room for the enlarger and at least 4 chemistry trays (dev, stop, fix, and a holding bath of water). Preferably you would be able to have the chemistry away from the enlarging area to avoid contaminating developed film and unused paper.
    Once your film or prints are fixed, they are no longer light sensitive.
    You will need film developer, print developer, stop bath, fixer, wash-aid, and photo flo.
    You can find out about specific brands of chemistry at the manufacturer's websites such as www.kodak.com or www.ilford.com
    There are many different options; just stick to the basics until you get it figured out. Then you can start trying different developers and techniques.
    The basic Kodak film dev is D-76. Their basic paper dev is Dektol.
    Indicator stop bath is nice, as it turns purple when it's no good. But some folks use straight water or water mixed with lemon juice or vinegar.
    There is fixer and rapid fixer. Rapid fixer acomplishes the job in less time. Some folks like to use rapid fixer because they feel that less time in the fixer leads to a higher archival quality.
    Kodak calls their wash-aid Hypo-clear. This helps wash the fixer from the prints. It is usually needed for film and fiber paper prints.
    Photo flo is a Kodak brand name. I don't know what other companies call it. It helps avoid water spots and mineral deposits on drying film.
    One more chemical, which is optional, but I find handy, is Hypo-check. This is used to determine if your fixer is still good. If you don't know, "hypo" is another name for fixer.
    Good mail order sites for paper and film are www.freestylesalesco.com and www.adorama.com
    I usually buy my chemistry at the local photo supply shop to avoid paying lots of shipping charges as chemistry can be heavy, but the above mentioned sites have a wide selection of chemistry too.
    Instead of print trays, I use plastic tubs I get at the hardware store. They are cheaper and have higher sides to help avoid spillage.
    Good luck. I set up my first darkroom in my bedroom about eight years ago. Now I am fortunate to have an entire room to dedicate to my photography.
  3. Tyjax
    Tyjax TPF Noob!
    Jul 23, 2003
    483
    Akron, OH
    So far as technique is concerned check out a beginners darkroom book at your local library or book store. Lots of good stuff. I began reading up and buying stuff about 6 months ago. Today I spent 4 hours in the bathroom which has become my darkroom. Lots of fun. One print. Unless there are mitigating reasons why you cant have the darkroom equipment in the bathroom just set it all up in your bathroom. I set my four trays (purchased at walmart) in the bathtub. I set my paper/focuser/tools on the toilet seat. I set the enlarger and easel on the sink. There is one window in the bathroom. Towel over window with thumbtacks, blanket over door with thumb tacks. Towel at base of door. VIOLA! Dark, Dark Dark room. you wont regret it. I am in love with the darkroom.
    Try www3.telus.net/drkrm/ I printed these documents out and have them in the dark room with me at all times. Invaluable.
  4. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    I think the generic term is wetting agent.
    My darkroom is inching closer and closer to completion. I bought a workbench that I am going to use as the dry side and it was delivered yesterday. Now I just have to take it apart so I can get it in the basement.
  5. Rockgurl
    Rockgurl TPF Noob!
    Nov 27, 2003
    Thanks so much... the replies have really helped, and I haven't built it yet, but I think I will sometime soon or after Christmas. Thanx again...
    ~Krysta[/code]
