Anyone used/own a Nikon 20-35 f/2.8?
Discussion in 'Photography Equipment & Products' started by Sw1tchFX, Jul 9, 2009.
  1. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I'm guessing nobody on here even owns one of these, they're getting a little scarce nowadays..
    I'm looking to replace my 24-120VR at the wide end because I need something that's faster, sharper, a little wider, small, lightweight, can take abuse, and can still take filters.
    From what i've seen, the 20-35 seems like it's the best bet, considering that I can get one in pretty darn mint at $700. The 17-35 is really nice, but I don't think I really need it, I rarely need to go wider then 24ish-mm, and the 20-35 is more petite.
    I'm curious on anyone's input on the lens. I have the 50mm f/1.4G, and 80-200 f/2.8D (2 ring), and this 20-35 looks to just be the wide version of the 80-200. I hate the crinkle coat, but whatever, I love the build of my 80-200 (it's been dropped on concrete and asphalt on two occasions, and nothing but a little gaffers tape fixed it), and I know the 20-35 will match the 80-200 in build.
    I just need a wide zoom option for when i'm doing work, because the 24-120, although flexible, isn't that great except at f/11ish, and when i'm at work, that's unacceptable.
    Thanks!!!
  2. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    I don't own one, but found a few reviews of this lens. It seems reasonably sharp with only the 14-24 the only lens that will easily trump it. It came out in 1993, and looks a lot like a mini 85mm F/1.4... lol
    It was replaced by the 17-35, but quality was not improved on much anywhere except the 30-35mm range where sharpness was better on the 17-35. You should be able to find a nice 17-35 for around $800-$900 for a good used one which is not much more (my mistake, I first said it was less), which is where I would be looking... but my heart is set on the 14-24... nothing else will do for me. :)
  3. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    I have one and yes its built like a tank. I think its about 9-10 years old (bought new by me). Never had a problem with it. The only thing I have to compare it with is a Sigma 24-70 f/2.8 in Canon flavor. But I have never done a side by side test between the two. Build quality is night and day between the two.
    Shot film and digital with it and have never had a shot where I determined the lens was at fault quality wise.
    One nice thing is it uses same filter size as the 80-200 (77mm) :D. If you can get a deal on it and need a lens in that range I would get it. I would wager the lens is better in optical quality than a third party lens covering the same range made today. Like for example my Tokina 11-16 f/2.8 which is a little soft. A very useable and good lens, but not quite as sharp as the 20-35 (different range of course).
  4. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Ok, cool that's good to know. Thanks for the replies!! I'm in the process of getting one for $700 minty, and i'm thinking it's a pretty good deal. If I don't like it, i'm confident i'll be able to sell it for at least $800.
    Thanks again for the replies!!
nikon 20-35 still relevant
nikon 20-35 vs 25-50
used nikon 20-35 review
