Aperture questions
Discussion in 'Photography Beginners' Forum' started by Abby Rose, Feb 21, 2010.
  1. Abby Rose
    Abby Rose TPF Noob!
    Feb 17, 2010
    642
    Michigan!
    Now, about aperture. I know that a low aperture setting is for bokeh, and a high one will give you those twinkle-y lights when you take pictures at night.
    But other than that, How do you know where to set them? I've been taking most of my daytime pictures at a low setting, and my nighttime ones at a high one. Is that a good approach? I do switch it up sometimes.
    When are you supposed to use a "middle setting"?
    I know this makes me look pretty dumb, but I AM new to this after all. :blushing:
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    How much DOF do you need/want?
    Answer that, and you will know what aperture to use.
    Try a picture wide open, f/4, f/8, f/16, f/22. The changes in DOF should be quite apparent.
  3. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Typically shooting wide open isn't the sharpest. For example, when I shoot birds I typically shoot in the f/4 - f/8 range. A lot also depends on the distance from the object, ambient light and background (distance from object to background as well).
    FYI, bokeh is just the out of focus area of your photo. The lower the number the more out of focus area you'll have.
    Hope that helps a little.
    http://www.dofmaster.com/dofjs.html
  4. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Also - when you say 'high setting' and 'low setting' are you referring to the f/ number?
    A smaller number is a larger aperture. If it helps to see why, think about it this way-
    It's a ratio. 'f' = the focal length of your lens. Say you have a 50mm lens. f/4 would have a physical aperture opening of 12.5mm (50/4). At f/8 it would be 6.25mm.
  5. Abby Rose
    Abby Rose TPF Noob!
    Feb 17, 2010
    642
    Michigan!
    Yes, sorry, the f/number. I should have been more clear. :blushing:
    You've all helped. Thanks!
  6. flyin-lowe
    flyin-lowe TPF Noob!
    Jan 5, 2009
    287
    6
    If you can get your hands on a copy of the book understanding exposure it will go a long way. Heres my explanation from one beginner to another. In short the higher the f number the more of the photo that will be in focus. Most lenses will be sharpest in the middle. If you have a subject that you want in focus and you want the background blurry use a lower f number (1.8-5 something). If you are shooting something and the background is close to the same distance away as the subject (like a shell on the beach, or a person standing against a wall) then a middle range f number would be good (8-11). If you are shooting an outdoor scene like of a house where there is a mailbox, then the yard, then the house, and then a mountain range in the back and you want it all as much in focus as possible then a higher f number should be used 16+.
    Of course this can all change if you have poor lighting or subjects are in motion and you need to change the shutter speed.
    Again the book is a must for beginners like me (I read it twice in a week and will probably read it again after I have some time to get out and practice.
  7. Abby Rose
    Abby Rose TPF Noob!
    Feb 17, 2010
    642
    Michigan!
    Is the book by Bryan Perterson? I just googled it.
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    That's the one.
    He also has a series of youtube tutorials - search for that too.
