Aperture+Shutter Speed+ISO=Confused
Discussion in 'Beyond the Basics' started by momma_morris, Oct 13, 2010.
  1. momma_morris
    momma_morris TPF Noob!
    Oct 13, 2010
    West Virginia
    Hello I'm new to this forum so I hope I'm posting in the right place! I've been taking pic's for a while with just a point and shoot camera, recently I purchased my first DSLR. I'd love to learn more about Aperture, Shutter Speed, ISO. I've found alot of sites just by using goggle but I'm so confused with it all! Is there a good site out there for beginning?
    Thanks,
    Christina
  2. Overread
    May 1, 2008
    23,310
    3,867
    UK - England
    Understanding Exposure by Bryan Peterson :)
    It's a book rather than a website but its well written and idealy suited to teaching you how to start using ISO, shutter speed and apertures both to achieve a correct exposure and going further to using the settings in a creative manner.
  3. MisplacedAngler
    MisplacedAngler TPF Noob!
    Nov 2, 2008
    120
    Arkansas
    What kind of photography are you into? If you're shooting mostly outdoor pics, then your ISO will typically be really low thus removing one variable from your equation and there is a direct relationship between your last two variables shutter speed and apature size.
    BTW, the book Overread recommended is good, but I learned most of what was in the book online before I ever bought it.
  4. edouble
    edouble TPF Noob!
    May 24, 2009
    715
    NEPA
    ISO directly affects your shutter speed. Higher ISO = faster shutter speed. There as a trade off with dslr and high ISO though. Higher ISO more noise (grain) in the picture.
    Aperature is related to the size of "hole" that light travels through to the sensor. The bigger the "hole" (smaller f number) the more light can travel to the sensor. More light going to the sensor = faster shutter speed. The smaller the aperture (large f number) less light travels to the sensor = longer shutter speed. A large aperature like f/2.8 gives a narrow depth of field (dof). A small aperture like f/22 gives you wide depth of field (dof).
    DOF is used to isolate a subject like a single flower (small f number). Or DOF is used to have an entire scene in focus like a flower garden (large f mumber).
    This is a very broad subject and requires pages of text and examples to fully explain.
  5. Babs
    Babs TPF Noob!
    Oct 1, 2010
    152
    Kent, UK
    I've bought that book on the basis of a recommendation from this forum, and it's great. Really well laid out, well written, and online support too (not that I've looked at that yet :blushing:)
  6. Rekd
    Rekd TPF Noob!
    Aug 13, 2009
    1,272
    51
    Rural America
    What he meant to say was;
    If you want to stop motion use a faster shutter speed.
    If it's dark out you'll want higher ISO and big aperture (small number), especially if you want to stop motion. (Hi ISO lets in more light, similar to a bigger aperture, but a high shutter speed kind of counter-acts that) The darker it is the more noise you'll get from higher ISO.
    If you want to focus both near and far away, use higher aperture. If you want to focus on a very specific area and blur everything else (Depth of Focus, DOF), use a lower aperture.
    I would suggest using Aperture Priority or Shutter Priority for a while to get used to how they work together. (For sports/action stuff, use shutter priority).
    I'm just bustin' edouble's chops. He gave a great explanation that you may be able to understand better after a few months of shooting and getting to know your camera.
  7. farmerj
    farmerj TPF Noob!
    Apr 26, 2009
    589
  8. KmH
    Apr 9, 2009
    38,728
    5,153
    Iowa
    The 3 - shutter speed - lens aperture - ISO - are inter-related and are known as the Exposure Triad.
    Some call it a triangle, but that is really a poor analogy.
    DSLR cameras have a built-in reflected light meter. We can center the light meter reading by adjusting one or more of the 3 parts of the exposure triad to make a properly exposed image.
    In a short time we discover that once we have centered the light meter we can keep it there by adjusting any 2 of the 3 exposure triad settings. The key is that if one setting is increased, the second setting must be decreased.
    As an example, if we let in more light by making the lens opening larger (larger aperture), we can get the same exposure by adjusting the shutter speed so it opens for a shorter period of time.
    Another similar example would be again letting in more light with a larger lens opening (larger aperture) but adjusting the ISO so the image sensor is less sensitive to light, instead of adjusting to a faster shutter speed.
    Aperture is one of the things that can affect if the foreground and background of a photo are in focus. That is known as depth-of-field, or DOF. In general, large lens openings are used to make the DOF shallow with the subject sharply focused but the foreground and background blurred. That's really good for making a portrait type photo, but not good for a landscape type photo where we want the entire photo in focus.
    Shutter speed can control if things are motion blurred or not. The longer the shutter is left open, the more chance things can move while the picture is being taken.
    So, if we want to take pictures of runners we use a fast shutter speed to stop the motion. For a photo of a flower arrangement made inside, we can use a much slower shutter speed because nothing in the frame is moving.
    ISO is just an adjustment that adjusts how sensitive to light the image sensor is. As the ISO setting gets higher, so does the amount of electronic nosie ther is in the image. The ISO setting has a bearing on what shutter speeds you can use. As the amount of available light goes down, we can increase the ISO to keep the shutter speed the same.
  9. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    12,029
    2,214
    Wichita, Kansas, USA
    :thumbup::thumbup:
    You can't go wrong with this book.
  10. shan35mm
    shan35mm TPF Noob!
    Oct 14, 2010
    4
    Australia
    Hi momma_morris,
    My website has posts that explain the very basics for each of these topics. It might be just what your looking for to clear the confusion.
    I'm not a spammer, so I won't post the address here. If you would like the address, just send me a message and I will send it over to you.
  11. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,665
    22
    California, USA
    Ugh better read the websites and books, found 2 errors is what people said above.. 95% correct though
  12. prodigy2k7
    Apr 22, 2008
    1,665
    22
    California, USA
    No. Changing your ISO only under or over exposes your photo. You compensate with changing aperture or shutter speed. For example: If you are in Tv mode, you are set to 1/500 and you change your ISO from 100 to 200, your aperture changes, not your shutter.
    This is a little misleading. A higher ISO can seem to give the photo more light exposure physically but no more light is actually entering the lens. Im pretty sure you already know this but want to clear that up for readers. ISO simply amplifies the signal the signal. The sensor receives the same amount of light depending on the shutter and aperture only.
aperture shutter speed formula
aperture shutter speed iso formula
apeture,shutter speed and iso formula
dslr aperture shutter formula
formula for aperture and shutter speed
formula iso shter speed and aparcher
how aperture and shutter speed work together confused
iso aperture shutter speed formula
law suggests that aperture and shutter speeds are directly related
