Aperture
Discussion in 'Beyond the Basics' started by abraxas, Apr 27, 2008.
  1. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    I shoot nikons in manual mode because I like to push the buttons and spin the little wheels. One thing I've wondered about though, is how come I can't set the aperture to the minimum size?
    For instance; one camera I have says the minimum aperture value is f/37. Anyone know why sometimes I can't set it below f/22?
  2. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,667
    22
    California, USA
    IMO - Just guessing, maybe the lens can only go to 22 but the camera can allow up to 37?
  3. Miaow
    Miaow TPF Noob!
    May 25, 2007
    885
    South of Melbourne, Australia
    I've found it depends on the lens setting with the canon (kit lens 18-55mm) - to get F36 it has to be on 55mm
  4. davidfromoz
    davidfromoz TPF Noob!
    Oct 24, 2007
    40
    On my Nikon 18-200VR both the maximum and minimum aperture vary with the focal length (zoom factor).
    I'm a bit of a newb here. But conventional wisdom says in most cases you don't want to take the aperture number really high because the image will be degraded. But sadly, if you follow the advice you don't get to spin the wheels as much.
    cheers,
    david
  5. ScottS
    ScottS TPF Noob!
    May 14, 2007
    2,334
    Denver, Colorado
    It depends on the lens. The camera has the ability to push the aperture to f/36, but the lens only goes to f/22.
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    The camera is nothing. It's a piece of software. It all depends on the lens. The design is when you zoom in on a lens with variable aperture like the 18-55 f/3.5-4.5 is that at 55mm the image is 2/3rd of a stop darker. The actual physical dimensions of the aperture blades does not change.
    So at 55mm you have the same range just 2/3rd of a stop darker instead of 3.5-22 you get 4.5-37. Diffraction would still limit you quite a bit above f/11 (or f/14 at the 55mm end) anyway, and the images would cease to be sharp.
  7. prodigy2k7
    Apr 22, 2008
    1,667
    22
    California, USA
    Ya, but I assume the mathematics on the camera only allows up to F36 maybe?
  8. abraxas
    Aug 15, 2006
    10,417
    9
    Thanks all.
  9. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Don't assume that. What this would mean is that you would not be able to say take a macro photo at the correct exposure. This isn't mathematics. It's a mathematical formula. The camera is not the limiting factor. Apertures are controlled by the CPU in the lens. When I mount my MicroNikkor f/2.8 it ranges from f/2.8-22 as per normal. But at it's near zoom the camera can set between f/7.1 - f/56. If the camera limited this at f/36 then it would not be compatible with the lens.
  10. prodigy2k7
    Apr 22, 2008
    1,667
    22
    California, USA
    ty, i said maybe :p lol
