Aperture
Discussion in 'Photography Beginners' Forum' started by echoyjeff222, Aug 7, 2010.
  1. echoyjeff222
    echoyjeff222 No longer a newbie, moving up!
    Jun 27, 2010
    633
    130
    WA
    The camera I'm looking to buy has an aperture from 2.8 to maximum of 4.0
    Is this enough to take good portrait and landscape shots?
    Also, how much should I be paying for a Nikon Coolpix P80 that is used?
  2. jeroen
    jeroen No longer a newbie, moving up!
    Oct 1, 2005
    1,133
    90
    Amsterdam, The Netherlands
    That camera has a maximum apperture of 2.8 wich will move to 4.0 at full zoom.
    It all has to do with the amount of light that can come trough the lense.
    The lower the number, the bigger the opening (the apperture) in the lense and the more light through the lense (so maximum is maximally opened).
    It has nothing to do with landscape or portrait shots. The Coolpix P80 is probably fine for that.
    If you want to know how much you should pay for a used camera you better do a search on e-Bay or a used camera website.
    Good luck on buying a camera.
  3. BuS_RiDeR
    BuS_RiDeR No longer a newbie, moving up!
    Oct 29, 2009
    2,356
    83
    Riverview, New Brunswick, Canada.
    Yeah that. :)
  4. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    Right... the aperture range is probably more like f/2.8(or f/4 at full zoom) if it's a P&S which the coolpix is, the most you can typically stop it down is to f/8.
    One other thing to realize is that when you read people referring to 2.8 as resulting in shallow DOF they are typically referring to the effect on a full frame, or at least aps-c sensor.
    The 2.8 on a P&S typically acts more like an f/8 or higher on a DSLR (meaning you will almost always have most of the image in focus).
  5. echoyjeff222
    Jun 27, 2010
    633
    130
    WA
    Ohh, ok. thanks for the clarification!
  6. KmH
    Apr 9, 2009
    40,742
    5,588
    Iowa
    The value of a used camera, or anything else, is totally dependent on it's condition.
  7. echoyjeff222
    Jun 27, 2010
    633
    130
    WA
    There's no scratches or anything on it. Works fine.
