I had bought two Chinar lenses on ebay. One is a 135mm. When i turn the apeture ring, nothing happens, I don't see the diaphram closing. Whats going on? Are 'long' lenses somewhat different than normal and wide lenses? This is the first long lens I've had. I suspect that they don't behave any differently, and that I should be able to see the apeture diaphram stopping down and opening up.
Here are two photos I took of the lens, the first is at f2.8, the next at f22. They're not different, and there is no movement inside the lens as I stop down. The photos are moderately large files, it was a rush job.
This is definitely a problem right?
f2.8
f22
f2.8
f22
