Are they in focus?
Discussion in 'Photography Beginners' Forum' started by Southerngal, Nov 25, 2007.
  1. Southerngal
    Southerngal TPF Noob!
    Jun 8, 2007
    299
    Georgia
    This is not that great of a pic....Im aware of that. I was just wondering if they appear in focus? It seems that my 50mm 1.8 lens is great when I have one person, but add a few and Im just not happy with the results. Is it me?
    [​IMG]
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    it appears to be fine...though the shortest boy appears a little blurry...maybe he moved...I dono.
    Good pic though. Looks like a happy family...without that cliche "say cheese" thing.
  3. jon_k
    jon_k TPF Noob!
    Jun 4, 2007
    213
    North Richland Hills (Ft. Worth suburb) TX
    Some lenses are soft around the edges. Unsure about this lens. You might read a review that tears the lens quality apart and you might learn about some limitations of the lens.
    You shot at around f/6. And f/8 is usually the sharpest... but f/6 isn't far from f/8 so it should be pretty sharp. I'd also expect a prime to be sharper than a zoom. You say its sharp as a tack with close up portraits? So would you say when you get some distance between you and your subject it gets fuzzy (such as a group portrait situation)?
    I am not an optical engineer, maybe the lens is mis calibrated somehow.
    A little PP can help though. You said its OK to edit so I will. If a 5 second PP can make the problem better, I say don't worry ;-)
    [​IMG]
  4. Southerngal
    Jun 8, 2007
    299
    Georgia
    Im actually working on the pic now....the Mother likes it. The one I posted had only been cropped a bit.
    Im a bit of a technical dummy....calibration issue? How would I need to go about solving the problem...or figuring out the problem?
    Thanks
  5. Southerngal
    Jun 8, 2007
    299
    Georgia
    Thanks. They were very fun to work with :wink:
  6. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    Check your depth of field. What aperature are you shooting at? To get multiple subjects on different planes in focus, you might try to stop down a bit to increase DOF. That's probably why the front subject is a little off. A bit of sharpening may help.
  7. Sweetsomedays
    Sweetsomedays TPF Noob!
    Jun 24, 2007
    788
    San Diego, CA
    What Soylentgreen said :) Love the colors and soft effect on the shirts though. Did you add a blur and erase back or get that in camera? Either way, it's spiffy.
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    jon_k how can a lens be mis-calibrated on an SLR? The camera's autofocus unit works on the same image as the photographer sees and everything is done through the lens. I posted a rather large post last month about focusing issues not being the lenses fault and no one was able to come up with a logical explanation of how a lens error could cause the camera to focus incorrectly. Do you have any input on this?
    Oh and with that edited version I would have preferred the sharpness layer to be masked onto only the subjects not the entire image, but that's personal taste stuff.
  9. Southerngal
    Jun 8, 2007
    299
    Georgia
    The first pic had only been cropped....no pp. Thanks!
    Here is my final edit.....The mother really loved the warm tones, so I went with it.
    [​IMG]
  10. luis_relampago
    luis_relampago TPF Noob!
    Oct 29, 2007
    54
    Houston
    Nice picture. They all look very sharp to me.
  11. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    None of us can reliably judge whether this is in focus or not. It's a tiny jpg. You should be able to see clearly enough if you view the full res file at 100%.
  12. JmPhotos
    JmPhotos TPF Noob!
    Oct 7, 2007
    42
    Be careful with your final edit Southerngal. It looks like you might have added a little too much saturation to your final edit. Your jeans turned purple. I only saw this because I did it too on a family pic. a few weeks ago. I was trying to get the fall colors in the background to pop more and ended up with purple jeans on the actual print from the lab.
    Jodie
