armor case for my SLR
Discussion in 'Photography Beginners' Forum' started by Lavarocker, Jan 29, 2007.
  1. Lavarocker
    Lavarocker TPF Noob!
    Jan 27, 2007
    8
    I live in Hawaii and take a lot of pictures on the beach and on the water. What do you all think about an armor case to protect the camera from sand and humidity?
    thanks!!!
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    what camera do you use? If you're shooting with a D200 or 1D, than i'd say don't worry about it, but if you're on a Rebel or D50 than yes, do it.
  3. Max Power
    Max Power TPF Noob!
    Jul 29, 2007
  4. maddermaxx
    maddermaxx TPF Noob!
    Jun 26, 2007
    72
    While thats good for dings and banging around. Not really made for humidity/sand
    If you don't have a Sealed body (Higher end like 1D's) Then your only true option for humidity/sand/splashes would be a underwater case or a bag of some sort.
  5. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Common sense and taking good care of your camera will help more than anything else.
  6. carusoswi
    carusoswi TPF Noob!
    Jul 15, 2007
    47
    Common sense and taking good care of my camera always meant to me that, if I wanted pictures of activities at the beach, then, I would not be part of the activities . . . I don't see how you can spend the day at the beach as a participant in the fun and still take pictures with anything more than a throw away camera.
    If you swim, play in the sand, etc., your camera is almost certain to get contaminated with water, worse, sand.
    Once sand gets in your camera or the lens, then, repair is generally prohibitive.
    Caruso
  7. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    I have my gear in Pelican cases. Water tight, they float, and I think a truck could run over it and the gear would survive. I use a 1650 for my cameras as a gig case, and a 1490 for the laptop, external HD, etc. They also sell small silica gel packs to absorb moisture when the case is closed, and they have a vent devise that keeps air pressure neutral while keeping out water/humidity. A worthwhile investment IMO.
  8. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    That whole armor thing seems like a good idea, but, I still think that it would hold moisture between the body and the coating unless taken off everyday.
  9. Proteus617
    Proteus617 TPF Noob!
    Jun 3, 2007
    410
    35
    Pelican cases are great, but I can't afford one. My Rebel lives in an old steel ammo case. Just as indestructible and water-proof, but MUCH heavier and doesn't float. Costs about $10.
  10. WDodd
    WDodd TPF Noob!
    Feb 20, 2007
    899
    Amherst (Cleveland), Ohio
    I take my camera gear to the beach all the time. I just place my bag usually in the middle of the blanket and make sure I dry/wipe my hands off before opening it up or using it. Never had any problems yet.
  11. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    I second Pelican if you can afford it.
  12. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    Pelican 1650 is over a $100 bucks and even more with the divider set.
    It is a WHOLE lot cheaper than cases from Lowepro or Tamrac.
    It is a WHOLE lot tougher and waterproof than offerings from Lowepro or Tamrac.
    It is certified for handcarry on US airplanes ( My cloths go under the plain not my camera stuff).
    and it is worth every penny.
    Seriously... save up and this case will serve you well for years of travel. I also have a cable hanging off of the padlock... I use it to lock the case to objects when it might be out of sight for a short time.
