Astro photo question
Discussion in 'Photography Beginners' Forum' started by Turnerea, Nov 18, 2009.
  1. Turnerea
    Turnerea TPF Noob!
    Aug 28, 2008
    212
    SoCal
    I've seen many pictures of this style:
    http://parkerlab.bio.uci.edu/pictur...new for web/big thumbs/tn_IMG_3177_tweak2.jpg
    (not shown in the post because I didn't take it)
    What techniques would you guess are at play here?? In my head its got to be one of two ways:
    *very high ISO to capture all that detail in the stars before trails can be formed. I'm thinking you'd have to have a full frame sensor to keep the noise down for high ISO for this option, and shoot at wide angles to allow the longest time possible.
    *a stack effect to get all the stars (with or without a moving mount?), then digitally combined to place the arch in front
    Obviously people won't know what really happened to make this picture, but maybe some people with experience with these types of shots can shed some light on how they accomplished them?
    Thanks,
    Erik
  2. battletone
    battletone TPF Noob!
    Sep 22, 2009
    285
    Somewhere in the lower 48.
    I am going to assume that is the exposure for the foreground. No way those stars were taken with a 137s exposure.
    So I would say it is a composite photo....with some photoshopped enhancements to more than a couple of the stars. But then I have only photographed the night sky a few times.
  3. astrostu
    astrostu I shoot for the stars
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    I would also guess composite. And I would guess some PP effect on the brightest stars as that does not look like an effect you would get from a cross-screen filter nor a custom-made diffraction spider.
    It's possible that it's a single shot at 137 seconds and just the foreground was processed separately from the sky and then put together after. I say this given the high amount of noise (red dots) near the center of the field.
  4. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    It’s possible to get a nice shot and merge them all in Photoshop as a smart object but it’s no piece of cake you are going to end up manually adjusting alignments of photos and all of them for the most effect will be all raw lot’s of raw images
    Look read this below it will tell you what this guy did. * He used a tracking tripod which is $$$*
    B33, The Horsehead Nebula this was taken in my homestate NJ where according to Dark Sky Finder map says there is null chance for a shot like this one below.
    [​IMG]
    Exposure Data
    • Lens: Astro-Physics 130EDT f/8 Triplet Apochromatic Refractor
    • F/stop: f/6 with 0.75x matched Telecompressor
    • Exposure: 4.5 hours total exposure:
      • RGB: 18 x 600 seconds
      • Ha: 9 x 600 seconds
    • Mount: Polar-aligned tracking equatorial mount, auto-guided
    • Camera: Canon EOS 20Da DSLR
    • Mode: RAW
    • ISO: RGB: 800, Ha: 1600
    • White Balance: Custom
    • In-Camera Noise Reduction: Off
    • Filter: RGB:IDAS LPS, Ha: Lumicon Hydrogen-alpha cut filter
    • Temp: RGB: 40F, Ha: 33F
    • Date October 22, Oct 26, Nov 25 2006
  5. astrostu
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    Just FYI, Astro-Physics telescopes are ridiculously expensive.
  6. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    But who mentioned a telescope?
    but heres another for the road using a nikon dslr
    Nikon D100 4 images exposed from 2 to 3 minutes, Nikon D100, ISO1250 setting, Tak TOA 130 with reducer (f5.8, 754mm), guided using STV eFinder.
    http://www.dl-digital.com/astrophoto/D100-astro.htm
    [​IMG]
  7. astrostu
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    Uh .... you did. The sucker's over $4700 (and discontinued). Its replacement, the f/7.5, starts at $5675.
  8. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    :lmao: Ok my mistake he hooked up the camera to the telescope yes
    but not everyone does this. You do need to track the same area so a telescope mount is a must but regular dslr and good lens mounted on a motorized equatorial tripod would be on a budget and give good results
    This one cost $700 from b&h photo
    CG-5 Motorized Equatorial Telescope Mount with Tripod
eos astro photo software witamina
image astro avec nikon d5000
quantaray star series 600
untouched astrophoto raw images taken with dslr camera forum
