astronomy camera
Discussion in 'Digital Discussion & Q&A' started by den9, Sep 6, 2008.
  1. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    hi i was using my D50 for taking pictures of the stars, then my cousin used his D80. he told me that the D50 had a better sensor for shots of the sky, but i didnt understand why.
    for 20 min exposures his pictures were coming out green, and mine were working fine.
    he also told me that for long exposures the sensor could get hot. is that true?
    if he ever sends me the pictures i could show u the green ones.
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    The colour shift can be due to heating and noise reduction. Sensors tend to get purple when they get hot, something older nikons are very susceptible to. The Noise reduction often turns this green afterwards because the already warm sensor is used again for a NR image. The NR image is then more purple than the original.
    Sensors of all kinds heat up significantly. In many cameras you can literally damage the sensor by taking a long enough exposure, although I haven't heard this affecting a current generation camera. Only the 350D, and I know my D200 gets DAMN HOT after 30 minutes.
    If you're interested in some astrophotography I suggest either shell out the many thousands for a dedicated sensor which is peltier cooled to maintain a noise free long exposure, or spend about $30 on ebay and go buy a roll of film :) The other option that's digital is to do image stacking. Searching for stacking on this forum should bring up quite a few threads.
  3. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    how come my D50 wasnt getting hot like the D80?
  4. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    bump?
  5. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    any1?
  6. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    The weather?
  7. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    we were shooting both cameras at the same time, it was probaly 65 degrees out
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    No reason to keep bumping threads in this subforum. Try that when it's off page one.
    Different sensor, different voltage, but most critically a different body. How do you know the sensor wasn't heating up, did you pull the lens off and touch it with your ear?
  9. potownrob
    potownrob TPF Noob!
    Jul 8, 2008
    312
    Poughkeepsie, NY
    :lmao: :lol: :lmao:
  10. Bifurcator
    Jun 1, 2008
    3,312
    Japan
    Hehehe good one Garbz! :thumbup:
    There are 100's of variables that can contribute to sensor heat.
    • Direct sunlight on on a black body,
    • Angle to the Sun,
    • Proximity to a busy memory card,
    • Speed and thermal properties of the memory card,
    • Shot interval,
    • Exposure length,
    • Proximity to a warm battery,
    • Live View Sensor focusing,
    • Proximity to any warm internal components (in my case AntiShake almost over-heats it),
    • How you hold the camera (hands/cloths as thermal insulator),
    • Camera Body material thermal dissipation characteristics,
    • Your breath (humidity has an affect),
    • Component age,
    • etc.
    Granted each separately may not be all that significant but it is additive.
  11. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    well therese were taken back to back, same temp, it was about 60 degrees out, and they were both long exposure shots, say 20 minutes
    first shot is with a D50, the greenish shots are with a D80
    [​IMG]
    [​IMG]
  12. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yep the pink is a clear sign of the sensor heating up. The green I will assume is the noise reduction trying to eliminate the pink.
    You should maybe consider an image stacking technique, the reset the sensor gets are every frame causes the pink noise to disappear (sensor still heats up though)
    [​IMG]
    http://www.tawbaware.com/imgstack.htm
