attaching an optical lense (canon powershot a70)
Discussion in 'Photography Equipment & Products' started by MuffinJuice, Aug 22, 2003.
  1. MuffinJuice
    MuffinJuice TPF Noob!
    Aug 22, 2003
    89
    fairfax va
    heya im new here
    i got a canon powershot a70 for my bday (im 15)
    and ive only taken a thousand pictures with it
    anyway
    im kinda disappointed that it cant get a good snap of distant things so i was wonderin if its worth getting an optic lense (and if you can get one) cuz the most ive seen is a 3X zoom which doesnt do too much
    any suggestions or is this the wrong camera to want to take the type of pictures i want.?
  2. doxx
    doxx TPF Noob!
    Aug 4, 2003
    499
    behind the viewfinder
    Your Canon is a very good small camera... the zoom range goes from 35-105mm which is pretty impressive and it covers a common zoom range for every day photography. Unfortunately, it doesn't look like you can attach any extension lenses to your cam...
  3. MuffinJuice
    Aug 22, 2003
    89
    fairfax va
    should i even bother with the 2x or 3x zoom?
  4. doxx
    doxx TPF Noob!
    Aug 4, 2003
    499
    as long it is optical (which your cam seems to provide) don't worry... digital zooms are pretty worthless IMHO
    happy shooting :wink:
  5. MuffinJuice
    Aug 22, 2003
    89
    fairfax va
    bah
    the optical zoom is like if i look through the regular sight (as opposed to the digital display) it looks the same as (same distance) if the camera wasn't there. when you zoom out, this get further away but you can see more. but it doesnt actually zoom unless i use the digitial zoom
    (which has worked if i dont use the digital zoom all the way and only on certain shots)
  6. jmherbison
    jmherbison TPF Noob!
    Aug 20, 2003
    28
    Puerto PeƱasco, Mexico
    Digital Zoom only lowers the quality of the image. You can do the same with any photo program. And when you use digital zoom focus is a big issue.
  7. MuffinJuice
    Aug 22, 2003
    89
    fairfax va
    this one focus' it alright its auto and junk with a digital zoom of like 4x the shot comes out pretty clean
  8. giantbunnyhead
    giantbunnyhead TPF Noob!
    Sep 10, 2003
    16
    Calgary, Canada
    You may have figured this out already, but there are quite a few attachment lenses for the A70. Various telephoto, wide angle and macro lenses can be found in stores or on something like e-bay.
    The digital zoom, it seems to me, is next to useless - seeing that you can take any digital photo and resample the image on a computer to get better results than if you were to use digital zoom.
    If what you are trying to do is capture an image from a distance, your best bet is to get the telephoto lens (I believe I've seen them come in 2.0X, 2.4X and 3.0X denominations). They are made by Canon, as well as a few other manufacturers.
    Hope that helps!
    kevin
    PS - don't forget the adapter!
    Adapter part # LADC52-C
    Canon Telephoto Lens part # TCDC52
    Canon Wide Angle Lens part # WCDC52
