B&W conversion with Photoshop Elements 5
Discussion in 'Digital Discussion & Q&A' started by invisible, Apr 3, 2009.
  1. invisible
    invisible Been spending a lot of time on here!
    Mar 10, 2007
    5,213
    977
    Canada
    I haven't been able to find a tutorial about this online, so I'm resorting to the helpful userbase here at TPF.
    Can someone explain in a few easy steps how to convert images to B&W with Photoshop Elements 5? I have tried to do it intuitively in a few different ways, but I always end up with images that lack contrast.
    I know next to nothing about this software (or about post-processing in general, to be honest). I don't know how to use layers or fancy things like that. What I'm looking for is an idiot-proof explanation in lay English. Let's just say I'm the master of the quick fix.
    Thanks for your help and mercy :)
    EDIT: I shoot RAW, by the way.
  2. MACollum
    MACollum TPF Noob!
    Dec 13, 2006
    404
    Oklahoma
    Having not used Elements I can only be of limited help. I suppose the fastest way would be to desaturate (not sure how in Elements though) but that won't really give you the best results. Try these links I got from Google:
    http://jfletcherphoto.wordpress.com/2009/03/13/photoshop-elements-tutorial-converting-to-black-and-white/
    http://www.which.co.uk/advice/photoshop-elements-change-colour-images-to-bandw/index.jsp
    http://www.photokaboom.com/photography/learn/Photoshop_Elements/color_to_bw/1_color_to_bw.htm
    HTH.
  3. Chris of Arabia
    Chris of Arabia Herding cats since 1988... Supporting Member
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    There is the 'Enhance | Convert to Black & White' option, but as you've found it is a little limited in scope (I'm assuming you're not using the Image | Mode | Grayscale option). The only way I've found with it is to convert using the style that most closely represents what you like the look of then adjust the Red/Green/Blue/Contrast options as necessary, but before you do the adjustment, move the slider as far left as it will go to keep control of the changes; it's very easy to over do it.
  4. invisible
    Mar 10, 2007
    5,213
    977
    Canada
    Thank you, guys!!
  5. Chris of Arabia
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    Any time...
