B&W digital camera settings?
Discussion in 'Digital Discussion & Q&A' started by Kernix, Aug 20, 2009.
  1. Kernix
    Kernix TPF Noob!
    Dec 13, 2008
    12
    Philadelphia, PA
    I have a Canon digital Rebel XTi and I want to shoot some cityscapes in black & white. I set the Picture Style to Monochrome with settings of 3, 0, R, N (that's sharpness, contrast, filter effect [Red] and toning effect [None]). Was wondering if anyone can shoots with different settings and why.
    Thanks!
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    The most common (and best IMO) advice is to shoot in Color (RAW) and convert to B&W with Photoshop or other software.
  3. Kernix
    Kernix TPF Noob!
    Dec 13, 2008
    12
    Philadelphia, PA
    That's what I'm hearing from other people - thanks!
  4. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    Agreed; shoot in color and do any B&W work in PP. This is also good because that way you're not stuck w/ a B&W version of a shot if it would otherwise work better in color.
  5. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    The settings you have are extremely limiting. You have played with the red effect I assume? It darkens the sky a bit and brings out people's skin tones. Great when photographing people but not much else. There are plenty of times when you would want to mimic a blue or green filter.
    In such cases it's always good to shoot colour and convert using your favourite software. Every software worth it's salt should give you some kind of option for blending the various red green and blue channels to grey.
  7. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    When shooting for B&W, in addition to what has been already said about shooting in color and converting, Shoot with the mind set of B&W. Don't think convertion, Think that you have B&W film in the camera. It's harder than it sounds especially when shooting digital but it helps with composing, color positioning, lighting and other compositional elements as they are slightly different than in color. I have too often seen when people are thinking color, shooting in color then try converting later and have crappy conversion results and can't understand why.
  8. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    Good advise, but hard to do for most people these days since most new shooters at least don't have black and white film experience. After 35 years of shooting I can turn on black and white any time I want. I sure shot enough cases if not truck loads of B&W film over the years. I doubt that a digital only shooter can envision black and white with out having that experience. This is just one more reason that I advocate that anyone that wants to learn photography ought to have some film experience. It teaches a different mindset. :D
  9. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    ahmen to the above statement
  10. flea77
    flea77 No longer a newbie, moving up!
    Feb 6, 2009
    593
    34
    Huntsville, TX
    Agreed! The best, and easiest way to make a B&W image is with B&W film.
    Allan
  11. table1349
    Sep 9, 2006
    4
    I'm not sure I would call it the easiest. It takes a knowledge and possession of a vast array of filters to shoot B&W film. Glass filters that are not needed for digital and are much easier and cheaper to duplicate in post processing. Film is the best way however to learn to think and train your brain to see in black and white.
  12. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    I disagree with the idea that learning B&W is best done with film. I see absolutely no advantage over using a digital camera that has a B&W mode. To me, its seems no advantage either way.
    The supposed advantage of film is, I presume, that you never see the photograph in color and, once shot, the conversion of the subject color into B&W tones is fixed. If you shoot B&W JPEG with very normal settings and no filter effect (not the red the OP is using) you have pretty much the same thing as shooting B&W film. For the real beginner, this is where you should start. As you develop an eye for "seeing" in B&W you can progress to more advanced techniques.
    For the serious shooter, shooting either B&W film with no collection of filters or shooting B&W JPEG w/o electronic filter ajustment is not optimal. To do good film work you need filters. To do good digital you need the electronic equivalent of the same. You to change your camera settings on a shot for shot basis. With digital, by far the best way to do this is to shoot RAW (which is always color) and do the B&W conversion in post processing to make the "filter" and tonal adjustments (contrast, ...) necessary.
digital camera with b&w mode
