b/w photography, any advice?
Discussion in 'Photography Beginners' Forum' started by sincere, May 4, 2007.
  1. sincere
    sincere TPF Noob!
    Jan 5, 2006
    475
    Berlin
    I know i am shooting with a d-slr but i think that there are still things to consider,right?
    The thing is whatever i did in color, when i try to switch in in b/w via PS, none of it comes out as nice as the color stuff.
  2. Kathleen
    Kathleen TPF Noob!
    Mar 26, 2007
    121
    Ontario
    I'm rather new to photography, so I'm not sure if this will help or not. I set my camera to black & white and then do what ever editing if need be in PS. I'm using a Canon 300D. This is one shot that I took set at black & white. As I said I'm new. :blushing:
  3. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
  4. Kathleen
    Kathleen TPF Noob!
    Mar 26, 2007
    121
    Ontario
  5. Kathleen
    Kathleen TPF Noob!
    Mar 26, 2007
    121
    Ontario
    P.S. Love your photos!
  6. The_Traveler
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    Please forgive me if I was abrupt.
    Since you are clearly working at being a better photographer, as far as I'm concerned you are one of us, one of the good guys and any misstatement isn't important.
    Thanks for the ataboy on the pictures.
  7. Kathleen
    Kathleen TPF Noob!
    Mar 26, 2007
    121
    Ontario
    No problem, I didn't think you were abrupt. I'm here to learn and help if I can. That is what the photoforum is all about right. :)
  8. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    To expand a little bit, you lose nothing by converting color to B&W in the post process and you gain a lot. Specifically, you can still manipulate colors in a black and white environment in the same manner that we did with colored filters on black and white film in the old days. Even if you don't intend to have a color image, capture it that way and then you will have more with which to work.
  9. JDP
    JDP TPF Noob!
    Aug 16, 2006
    285
    Minneapolis, MN
    I really like the Rob Carr B&W conversion method for a lot of my work - he's the retoucher Greg Gorman uses - check out the technique here. Scroll down until you see "The Rob Carr Black and White Conversion Technique" and see what you think of it.
  10. sincere
    sincere TPF Noob!
    Jan 5, 2006
    475
    Berlin
    I checked out that Rob Carr technique and i think i did something wrong because i dont see much difference..
  11. Peanuts
    Peanuts TPF Noob!
    Jun 16, 2005
    2,905
    85
    Canada
    I personally shoot in Colour, then convert later. I use two different methods, one the "Gradient Map/Channel Mixers" and the other in which I switch to lab mode, delete a few channels, then revert back to RGB to use curves.
    I often find that black and whites need a pretty significant curve/contrast boost after being colour to remove this kind of grayish haze.
    Here is the change between one of my colorus and using the Gradient Map 'process'
    [​IMG]
    [​IMG]
  12. sincere
    sincere TPF Noob!
    Jan 5, 2006
    475
    Berlin
    Those pics are nice!
    Using curves and all, i am having a hard time finding the right setting . Is there any advice for working with curves?
