Backdrop advice for FAll Indoor shoot...please
Discussion in 'Photography Beginners' Forum' started by Rosy, Sep 21, 2011.
  1. Rosy
    Rosy No longer a newbie, moving up!
    May 9, 2011
    1,289
    328
    Raleigh NC
    Hello there
    I've been asked to do family fall pictures at a DayCare. My first option is outdoors - but since it's an all day shoot, i'm scared of the mid-day sun and also the unpredictable weather forecast
    IF i were to shoot indoor - what backdrop do you recommend. A fall themed one or a solid color one (like the one below from b&h)
    Won Background Muslin Modern Background - Deep MM10911010 B&H
    I am not doing individual portraits - they will be group sittings
    Wanna avoid cheap/cheesy outcome -
    I will be setting up props: hay/scarecrow/pumpkins, etc...
    one last thing - would you risk and do outdoor - what would you do to avoid mid-day sun
    appts - between 8am and 10am then from 3pm to 6pm
  2. Destin
    Destin No longer a newbie, moving up!
    Sep 11, 2010
    2,365
    435
    Western New York
    If you're doing indoor... do you have studio lighting? If you don't outdoor may be the only real option.
  3. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Hi Rosy, I'm from Raleigh too.
    Westcott and Lastolite make nice collapsible backgrounds, but probably more expensive than a single muslin background. Lastolite particularly have a nice fall colors background that I like. But depending the size of your group shots, they may not be the best choice this time around. Each (and others) make large scrims that are used overhead to cut mid-day harsh lighting.
    As we're coming into autumn and the days are getting shorter, the times you've chosen shouldn't be too hard to manage. Scheduling an outdoor shoot is practical with the props you have in mind, but you should also have a contingency plan because the weather may not play in your favor.
  4. KmH
    Apr 9, 2009
    39,370
    5,310
    Iowa
    Outdoors you put a diffuser(s) between the Sun and your subjects to create your own open shade, if you don't have open shade readily available, and then you use strobed light to make the exposures.
    A nice outdoor diffused light technique is to gel the strobed lights with a full CTO gel, and set the camera white balance to Tungsten.
    • Like Like x 1
  5. katerolla
    katerolla No longer a newbie, moving up!
    Oct 25, 2008
    202
    26
    Newcastle Australia
    out door is the way to go, find a nice background in the shade where you can work all day use a on camera flash and try to bounce it of a ceiling or something near by, if there is no bounce available like under a tree than use a defuser.
    with the muslin backdrops i found that there is too much pp after the shoot so if you realy have to get one get the paper rolls much less if any pp required
  6. Rosy
    May 9, 2011
    1,289
    328
    Raleigh NC
    Yes - I have lighting
  7. MissCream
    MissCream No longer a newbie, moving up!
    Sep 9, 2010
    1,855
    452
    Canada
    A day care shoot with just group poses all day????? Sounds like hell.
  8. Rosy
    May 9, 2011
    1,289
    328
    Raleigh NC
    thank you sooo much - do you have images that show this effect
  9. Rosy
    May 9, 2011
    1,289
    328
    Raleigh NC
    hell - would be correct, thanks for the support
  10. Rosy
    May 9, 2011
    1,289
    328
    Raleigh NC
    Can you give me your opinion on a solid colored muslin or a themed one?
    PLEASE - I need a contingency plan...
  11. MissCream
    Sep 9, 2010
    1,855
    452
    Canada
    I would just use a white muslin and grab some fall themed props from the dollar store or something. Do you have a background stand?
  12. Rosy
    May 9, 2011
    1,289
    328
    Raleigh NC
    KmH - you wrote...then you use strobed light to make the exposures.
    can you break this down for me...i apologize. Lighting is not my strength.
    I have an SB-900 speedlight - I have a portabe stand with a diffuse/shoot thru umbrella. Can i use this - if so, where in relation to the subject should i position it
cheap autumn photo backdrops
fall backdrops
fall backdrops for pictures
fall photo shoot backgrounds
fall photography backdrops
indoor fall photo background ideas
indoor fall photo shoot
indoor fall photography
indoor fall photos
indoor fall photoshoot
