Background for still life
Discussion in 'Photography Equipment & Products' started by ilghila, Dec 18, 2006.
  1. ilghila
    ilghila TPF Noob!
    Dec 4, 2006
    5
    I want to buy some kind of fabric to use as a background in still life photos, but I'm wondering which is the best kind of textile. What characteristics should I look for? Thank you.
  2. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    They will be your prints and so it's your call. I cannot, should not, will not attempt to dictate your taste.
  3. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    A solid color is all I ever cared about. Flat matte if you are going to light it. Otherwise I can't think of anything that makes one better than another.
    How and what you attach it to probably makes more difference than the material itself.
  4. basil_chiu
    basil_chiu TPF Noob!
    Jan 3, 2007
    11
    Eastern Ontario
    I think it depends on what your goals are, especially the mood you're trying to convey.
    Also, it depends on the scale. If your still life is human scale, you may want a photo backdrop because they don't have seams. I've used aluminium foil taped together to photograph kitchen gadgets.
    You can always use darkness as a backdrop. For example: clear out your garage, put your subject on one side, put your camera between the subject and the wall, then aim for the dark emptiness. (Of course, only light the subject). This is the blackest, cheapest backdrop of all.
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Bedsheets are my favorite.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    This is a good place to start. How big do you need it? A large piece of paper would make a great background for smaller stuff. It can be curved to cover both the area behind and under the subject...leaving you with a seamless transition.
  7. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    As said, it's entirely up to you, and what your concept is. That being said, for my still lifes, I normally don't use any kind of fabric. I prefer to use large sheets of foamcoare or mat board in different colors. I have one piece of foamcore which I have roughed up by creasing it in several spots, to give a weathered look. The advantage to using boards as a background is that they are easily propped up. If you buy thinner mat board in long sheets, you can curve it and have your subject on the board, and have the board curve up behind for a seamless look.
  8. ilghila
    ilghila TPF Noob!
    Dec 4, 2006
    5
    Thank you all, guys!
  9. mysteryscribe
    Feb 1, 2006
    6,071
    Well most of my stuff is small so I have two two by two sheets of very thin playwood from the home depot (no plug intended) the are attached with duct tape then spray painted black one one side and white on the other. Just to prevent see though on the cloth. I put them on a table inside or outside. Toss a small piece of cloth over them to make a seamless back drop. Very portable to follow the light and very easy to toss a cloth of any color over. I do not shoot cars though or anything else of any size.
    Ps you can put your own seam in black backdrops it doesnt show. Unless you mix up the cloth somehow.
