Bad Dog
Discussion in 'The Black & White Gallery' started by abraxas, Mar 2, 2009.
  1. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    [​IMG]
  2. Peter42
    Peter42 TPF Noob!
    Dec 31, 2008
    73
    Tecklenburger Land
    Cute shot, i like those bad scenes. Hope, the dog didnt bites you. ;)
    Ok, the Light is correct, i can see a lot of details in the wooden materials, the cut denies all the light from behind, only the little green in foreground is overapertured(did i say that right?)
    Good work in a hard valuerange of light and shadow
    greetings peter
  3. sephira
    sephira TPF Noob!
    Mar 2, 2009
    45
    Carencro, LA
    Ooooo! I like it very much! The lighting and composition are great!!
  4. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    I'd like for you to explain to us what all you did in post to this one to come out as it does. The light looks like it had been glaring! Against all that, you must have done quite a lot in order to bring out the texture of the wood. You did not carry any strong strobes into the desert, I assume...
  5. abraxas
    Aug 15, 2006
    10,417
    9
    Thanks. You're close- I'll explain below.
    Thank you.
    The original shot was taken in March 2003. The recent processing is in my usual quest to make bad shots work for fear of having to retrace the trillion (somehow that doesn't sound like so much anymore) odd miles I've traveled in the 14-15 years to reshoot everything with a decent slr.
    Shot with a Nikon 990 in auto mode, I metered on the dark shadows which blew out the light areas totally. I did a crop closer to the building leaving just enough sky and vegetation in just to make it make sense. I did levels and curves adjustment layers on the building, and adjusted the shadows to bring out the grain and separations between the railroad ties. I burned the highlights in the foreground and the door and window openings to hide the interior giving (I hope) some depth to the structure.
    Not my best work, but acceptable.
