Bad dust... Shooting a wedding later today.
Discussion in 'Photographic Discussions' started by RMThompson, May 9, 2009.
  1. RMThompson
    RMThompson the TPF moderators rock my world!
    Nov 12, 2006
    1,888
    11
    Ok, so maybe "shooting a wedding" is a bit dramatic, I'm shooting for a friend whose 63 year old mother in law is getting married at their home. Still, sensor dust is killing me, and they deserve the best photos I can take.
    Yesterday during my normal shoot I noticed it was worse than normal. I've only had it cleaned once, because normally at low F-stops I never notice it. I am sure at the wedding in the house I'll have the f-stop stuck between 1.8-3.5, but STILL if anyone knows any methods to get this off of my D50, I'd love it. I'd much rather use this camera than my backup.
    If anyone knows of any quick methods that don't require a bunch of drying time or something, let me know! :)
    Here is a sensor test at f22 against the sky:
    [​IMG]
  2. Overread
    May 1, 2008
    24,079
    4,175
    UK - England
    gah that is bad!
    ok best method I use is the following:
    1) set the camera up on a tripod - that way you have both hands free - the the tripod so that the camera his held with the lens opening downwards.
    2) Take of the lens opening cover and also use the cameras manual cleaning mode (that will flip the mirror up and expose the sensor. Note that you must have well charged batteries in otherwise it won't let you)
    3) Take a blower - NOT compressed air - I use a Giottos rocket blower - blow it a good few times in any direction away from the camera to just clean it out and make sure it won't blow dust into the camera.
    4) use the blower to blow into the camera opening - make sure that you use one hand to hold the nozzle end so that it does not touch the sides and don't push it so far in that you end up touching the sensor. Make sure to pause and remove the blower every so often to allow dislodged particles to fall out of the case.
    Spend some time over this and then see the results you get - anything not moved by that will need a more contact based cleaning kit
  3. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,186
    940
    Woodbridge, Ontario, Canada
    This sensor cleaning kit from Photographic Solutions has had positive comments.
    A blower would be handy also [as mentioned above].
  4. RMThompson
    Nov 12, 2006
    1,888
    11
    Thanks guys. Im going to see if a local shop can handle it. If not, I can deal with it for today, because Ill be opened up most of the way and it doesn't show as much. Thank God for Photoshop! :)
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Just use a rocket blower, it will at elast get the squiggly ones out.
  6. RMThompson
    Nov 12, 2006
    1,888
    11
    Well the local Ritz Camera is going out of business and had hardly anything... but they DID have one of those cheap blower things with the brush at the end. I dissasembled it and took the brush out, and used it as a blower. Here are my second tests. It seems the BIG piece moved.. we'll see if that's a good thing or a bad thing:
    [​IMG]
  7. captainkimo
    captainkimo TPF Noob!
    Apr 26, 2009
    65
    That was a big improvement, RMThompson. Did you find any dust particles in your viewfinder? Sometimes, when you use a blower, the dust in the sensor tends to transfer to the viewfinder (if that's the case, well at least, those particles won't be seen in the photos).
    This website is a good reference for cleaning digital cameras.
    Cheers!
    Captain Kimo
  8. blash
    blash TPF Noob!
    Nov 19, 2008
    599
    @RMThompson - what's that big bright spot in the middle of your picture?
  9. RMThompson
    Nov 12, 2006
    1,888
    11
    Not sure. I think its just a refraction from shooting in the full day. Reflection or something... but I didnt take any test shots after that at F22 to check!
  10. RMThompson
    Nov 12, 2006
    1,888
    11
    Yah in fact ive had dust in the viewfinder for a LONG time. I guess I should look into that too!
  11. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Man, that's some bad dust.
    I have to say - I never expected to see a 'sensor dust' thread from you. I guess I kind of expected you to already be on top of this. Get yourself a good sensor cleaning kit. There are many out there (though I like the Copper Hill kit).
    Your second results look better, but not optimal. You need a wet cleaning - blowing on it can only get you so far.
    After a properly done wet cleaning, it will be spotless.
  12. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Not really a big deal. If you can see it through the viewfinder, it won't show in the pictures. It *might* find it's way onto the sensor some day, but other than that - I would just ignore it.
