banding in my gradients
Discussion in 'Beyond the Basics' started by kkamin, Apr 1, 2010.
  1. kkamin
    kkamin TPF Noob!
    Aug 25, 2009
    514
    17
    Minneapolis
    [​IMG]
    On my monitor, I can see banding in the radial gradient on the background. I created this in Photoshop. Why is this happening? Is there anyway to avoid this?
  2. Chris of Arabia
    Chris of Arabia Herding cats since 1988... Supporting Member
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    Gradients are something that Photoshop doesn't really excel at from what I can gather. It might be worth trying putting a 50% grey layer over the top of it, then apply a Gaussian monochrome blur over the top of it with a high'ish radius applied to it. Then just vary the opacity of that layer till you get the effect you're after.
  3. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Two reasons usually cause this. Editing in 8bit rather than 16bit mode in photoshop, and colour space conversion errors. How did you go about editing?
  4. kkamin
    kkamin TPF Noob!
    Aug 25, 2009
    514
    17
    Minneapolis
    I edited in 8-bit srgb. If I edited in 16-bit, wouldn't this happen when I convert from 16-bit to 8-bit anyways? Thanks, Garbz.
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    No. All colours in the sRGB gamut can be displayed in 8bits. So the conversion from 16bit to 8bit would not give any noticeable difference.
    If you open an 8bit image you have limited data to work with. So you bump up the contrast and photoshop starts to make educated guesses. The more you work the image the nastier these guesses get. The first places these guesses become obvious is in shadows and gradients.
    If you start with a 12bit RAW from your camera, open it in CameraRAW as a 16bit file, then you have a lot more information to begin with. To put this in perspective: A 12bit file represents 4096 possible values. An 8bit file only 256. So you get a factor 16 increase in data that makes your educated guesses more accurate.
  6. kkamin
    kkamin TPF Noob!
    Aug 25, 2009
    514
    17
    Minneapolis
    Sorry I'm a little confused.
    So it would be better to work in 16-bit srgb and then when finished convert to 8-bit for output?
  7. Chris of Arabia
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    Correct
  8. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Yes, but this will not always eliminate banding.
    If banding persists in the reduced 8-bit output file you may need to add a little noise to the gradient while in 16-bit mode. This will dither the boundary between the two tones, blues in the original example, making it much less noticeable if noticeable at all.
  9. Dmitri
    Dmitri No longer a newbie, moving up!
    Jun 20, 2008
    5,879
    39
    End of the line
    Be aware that 16 bit PSD files are quite a bit larger than 8 bit, so unless it's a photo you plan to do something with - save your HD space.
    That said I seem to recall seeing a tutorial once about using curves to get rid of banding. I can't seem to find it but maybe it sparks someone else's memory?
  10. KmH
    Apr 9, 2009
    40,526
    5,539
    Iowa
    With memory running about $100 per TB, image file size is becoming less and less of a concern.
  11. Dominantly
    Dominantly TPF Noob!
    Jul 30, 2009
    3,032
    166
    San Diego, CA (RB)
    I think it just has something to do with the gradient you are using/ the way you are creating it.
  12. kkamin
    kkamin TPF Noob!
    Aug 25, 2009
    514
    17
    Minneapolis
    thanks
