Basic Filters
Discussion in 'Photography Beginners' Forum' started by eccs19, Jul 22, 2008.
  1. eccs19
    eccs19 TPF Noob!
    Jun 30, 2008
    571
    6
    Lisle Ontario Canada
    So I've got a *ist D on route to me to use with my current Pentax lenses. One of the lenses has a filter on it, but I don't remember if it is anything special. I think it mostly to protect the glass. Just wondering what would be recommended for filters for a basic kit.
  2. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    Some people put useless UV filters on their lenses to protect from scratches. I think this is what you are referring too. Some people believe the cheap uv filters can impede the image quality of your pictures. Some people use hoods instead of uv filters, and some daredevils don't even use one. This is up to you.
    Additional filters you may want to consider are:
    A circular polarizer - Kindofa must if you take pictures outside
    If you are big on landscapes and/or waterfalls you need a neutral density filter and a graduated neutral density filter. The adjustable ones such a the Cokin P series (or equiv) are the best for graduated nd filters.
    If you google circular polarizer and/or graduated nd filters you will find much more information.
    Most other styles of filters are now redundant due to advances in software.
  3. tirediron
    Jul 8, 2005
    40,649
    12,306
    Victoria, BC
    There are varying opinions on the use of UV filters as "Front element protectors". Personally, I'm a fan of it, and have either UV filters or B+W clear glass "filters" on all of my lenses. As far as effects filters, here's my recommendations:
    1. Circular polarizer to enhance contrast between sky and cloud, to make colours "pop" and to reduce/eliminate glare and reflection on subject surfaces.
    2. Graduated Neutral Density filters for use in landscape and outdoor work to prevent over-exposed skies and/or underexposed ground areas. Works by having a darker, but optically clear area at the top transitioning to clear at the bottom.
    3. Neutral Density filters, as above, but the whole filter is dark; used when you need a longer shutter speed, for instance to get the soft, flowing effect commonly seen in waterfall images.
  4. johan.sie
    johan.sie TPF Noob!
    Jul 18, 2008
    92
    hi guys,
    meanwhile we're discussing filters here, I am also hunting for a uv and c-pol filter from B+W. They have the MRC and non-MRC type. Does it actually really bad if its not MRC as far as the built?
    I was thinking of maybe doing non-MRC UV and MRC c-pol since it will be on the outside thread.
