Basic questions about Cokin Filters
Discussion in 'Photography Equipment & Products' started by Dweller, Apr 8, 2005.
  1. Dweller
    Dweller Inconspicuous Supporter
    Apr 19, 2004
    668
    Portland, Oregon
    if I understand Cokin system filters correctly they are square and fit into a holder that threads onto the lens.
    So, if I have a holder for a 56mm lens and a 52mm lens then I could use the same filter on both right?
    Do the filters just lay in the holder or are they secured somehow?
  2. SWFLA1
    SWFLA1 TPF Noob!
    Aug 23, 2004
    241
    you are correct - to use the filter holder on different lenses, you simply need the correct adapter rings... the filters slide into the holder. I've never had one fall out, but they are only held in by pressure points..not real secure, but not bad.
