Battaash (horse)
Discussion in 'General Gallery' started by Al-Wazeer, Apr 10, 2009.
  1. Al-Wazeer
    Al-Wazeer TPF Noob!
    Dec 25, 2008
    1,174
    Bahrain (somewhere in mid east)
    it's called Battaash or al-abtash, i don't remember, but it means the furious , his origin is arabian, but was birthed in UK.
    [​IMG]
    what do you think??
  2. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    Was this and HDR? if so I am not digging the HDR or tonemap on this it make it look like the horse was cut out and pasted in the background.
    As well there seems to be a bit of a halo on the horse.
    As well the background, it looks like this was shot in a junk yard.
  3. Al-Wazeer
    Al-Wazeer TPF Noob!
    Dec 25, 2008
    1,174
    Not an HDR, highlight and contrast only and some cloning in the BG
    it was ALMOST a junk yard
    didn't understand what you mean with "halo on the horse"?
    thank you for commenting :)
  4. jamagica
    jamagica TPF Noob!
    Apr 10, 2009
    153
    the backdrop is really great...an unexpected twist in a horse photo. I think if there was "mechanical" junk in the back it wouldn't be fitting, but this works out just fine. I think speedtrap meant the basic outline of the horse is so sharp that it seems to "glow" on top of the background. maybe soften the photo overall to merge everything together nicely? I definately like the way you contrasted this pic, the horse's glossy grays and browns balance out the strong change between its own tones and the background's.
    don't know if that made sense but overall..this looks great. If I were to suggest one more thing it'd be too try some off center cropping...this could really be your "signature" work if you toyed with the composition.
  5. Al-Wazeer
    Al-Wazeer TPF Noob!
    Dec 25, 2008
    1,174
    thanks for the comment!
    about the glowing, i always have this effect because of over-processing i think :p, i need to reduce processing :p
    about centering the horse i had to, because the owner was at the right and a boat in the left, so unfortunately centering was a must :(
  6. Wyjid
    Wyjid TPF Noob!
    Mar 28, 2008
    836
    Muskoka Canada
    i gave this one a shot. for the halo (bright edges around the horse) take the burn tool set to highlights on about 10-15% 0hardness, and go all the way around the horse till there are no white lines. the blur tool on about 15% and soften the edges a bit. I used burn shadows on the background to even out the lighting a touch. and i magic wand selected the sky and made it blue instead of white. just dodge the lower part of the sky to lighten it a touch. maybe this isn't the look you were going for though, so don't worry about it. Beautiful horse.
    [​IMG]
  7. Al-Wazeer
    Al-Wazeer TPF Noob!
    Dec 25, 2008
    1,174
    you've done great job with the burning and blurring, but the sky isn't really good, it's fake, but the burning did take the glowing away!
    anyways thanks for commenting and taking some of your time to edit the photo!
  8. Wyjid
    Wyjid TPF Noob!
    Mar 28, 2008
    836
    Muskoka Canada
    yeah, i didn't spend much time on the sky. it would probably be better if it were lighter. you could play around with that. but it's an option instead of a blown white sky.
  9. Al-Wazeer
    Al-Wazeer TPF Noob!
    Dec 25, 2008
    1,174
    i'll give it a shot, thanks alot wyjid!
  10. timethief
    timethief TPF Noob!
    Jan 28, 2009
    909
    19
    good contrasts. too bad background was not good enough.
  11. Al-Wazeer
    Al-Wazeer TPF Noob!
    Dec 25, 2008
    1,174
    sometimes, not everything is under your control, thats one of the difficulties of photography, thanks for the comment!
  12. jamagica
    jamagica TPF Noob!
    Apr 10, 2009
    153
    once again, the background was definately "good enough"...classic ranch settings are too pish-posh...In regards to your centering problem...makes much sense, so great job on the photo.
