Battery Performance
Discussion in 'Photography Beginners' Forum' started by Ptyler22, Jul 20, 2008.
  1. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    Hey guys, I just ordered a Canon 40D after 3 months of searching! But I want to make sure that I maintain the battery performance to get the most out of it and the replacement I bought with it. WHat things do you do to keep the battery working at its best? Also is it best to run the battery completely out right when you get it or charge it before you use it for the first time? Thanks guys!
  2. Crosby
    Crosby TPF Noob!
    Mar 7, 2008
    269
    Arkansas
    I think you want to charge it before you use it. That is Canon's recommendation in the manual I think. It is always a good idea to let the battery fully discharge before charging after that first use.
  3. tirediron
    Jul 8, 2005
    40,880
    12,415
    Victoria, BC
    I always ensure a battery is fully charged prior to it's first use, and then, as best I can, drain them and recharge them fully.
  4. Ron Evers
    Ron Evers Been spending a lot of time on here!
    Jun 28, 2008
    6,144
    2,015
    In the country just north of Toronto, Canada
    My charger has a setting to discharge the batteries & then charge them. It is recommended to use this setting after a few regular rechargings.
  5. uplander
    uplander TPF Noob!
    Mar 22, 2008
    536
    S.E. WI.
    New batteries should be charged for a full 10 to 12 hours even if the fully charged light is on after an hour or two.
  6. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    I wouldn't worry too much about it. These lithium batteries are pretty good.
    Also, I use (and recommend) off brand batteries like those from Sterlingtek.com. They are very inexpensive and last longer than the Canon brand batteries.
  7. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    OK, thanks guys, I got a replacement battery with it that was only $15 so it's not much, they last pretty long (or so the manufacturer says) so I think they should be good, Thanks!
  8. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    It is my understanding that the memory effect in NiMH batteries is not present in Li ion batteries. I don't run mine down all the way and haven't seen any problems. I did buy a bunch of cheap replacement ones on amazon too for backups (and those work just fine).
  9. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    Does the charger that comes with a 40d have this setting?
  10. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    I GOT MY CAMERA TODAY, 3 Days early!!!
  11. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    So I shouldn't use the battery at all before I charge it the first time? I looked in the manual and I didn't see anything about it.
  12. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Probably not. It's a PITA, I know...having to wait before you play with your new camera...but that's what they say is best for the battery.
