Beginner C&C
Discussion in 'Photography Beginners' Forum' started by weaves, Mar 24, 2010.
  1. weaves
    weaves TPF Noob!
    Mar 24, 2010
    New Zealand
    [​IMG]
    [​IMG]
  2. wlPhotography
    wlPhotography TPF Noob!
    Mar 24, 2010
    13
    Dallas, TX
    Welcome! With your current photos I would recomend lowering your exposier some. These photos are a little over exposed meaning to bright. Also try a higher aperture setting maybe around 5-6 if you have that functionality on your camera. This will allow you to have the background in a little better focus.
    Hope this helps!
  3. PerfectlyFlawed
    PerfectlyFlawed TPF Noob!
    Feb 2, 2010
    2,408
    19
    Tempe, Arizona
    way to over exposed.
  4. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,068
    89
    Kankakee, IL
    When photographs have a subject, foreground and background, the viewer can perceive depth. Often, a composition includes lines (formed by roads, streams horizon lines, etc.) that lead the viewer's eye to the subject.
    You have some foreground here, and background. But it's not really obvious where the subject is in either of these views.
    I hope this helps.
    -Pete
  5. reznap
    reznap No longer a newbie, moving up!
    Feb 2, 2010
    2,410
    64
    Ohio
    You're using a Sony point and shoot in the panorama mode?
    The camera did a decent job stitching them together, from what I see.
    Yes, they're overexposed. Your ISO is up at 1600 for these, at least the exif says that. I'd try to keep that much lower in the future. Most compact cameras don't take very high quality pictures at anything above 400 (at least the ones I've used).
    Another thing, venture out a little. Pictures of the backyard are great if you want to sell your house. New Zealand has to be one of the most beautiful locations on our planet, let's see some of it.
    My advice is to learn how to use your camera in manual mode, practice until you're getting some good and consistent results. Once you're comfortable with that, put some thought into what you're photographing and the placement and position of your subjects.
    Hope to see more from you, good luck!
