Beseler 23C Lensboard and 80mm Lens
Discussion in 'The Darkroom' started by wjk, Jan 21, 2007.
  1. wjk
    wjk TPF Noob!
    Jan 7, 2007
    15
    Hello---I'm wondering if I can use an 80mm lens with the same lensboard (Beseler 23C) that I use my 50mm lens with (there is a 39mm retaining ring---will ones made by Rodenstock work with other enlarging lenses)?Also---I have seen Beseler lens boards that do not require a retaining ring---has anyone used one? Thanks!
  2. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    Almost all enlarging lenses will be M39, so there shouldn't be any problem. I've never used the boards that don't require a retaining ring, but I assume that just means the hole itself is threaded.
    I've made several lensboards for my 23C enlarger, other enlargers, and several vintage view cameras, from thin sheets of wood and aluminum I found in the remote control airplane section of my local hobby shop. My homemade lensboards don't have the little ruby safe filter for seeing the aperture ring, but other than that they work fine.
  3. Majik Imaje
    Majik Imaje TPF Noob!
    Feb 15, 2007
    285
    Point Hope Alaska
    .. out of Plexi glass either painted flatblack on each side or merely taped!
beseler 23c
beseler 23c 50mm lens
beseler 23c ii lens board
beseler 23c lens
beseler 23c lens board
beseler 23cii lens board
beseler 80mm
besseler 23 c lens
how change beseler 23c lens
lenses for beseler 23c ii
