Best 2 lenses for Canon 7D
Discussion in 'Canon Lenses' started by karimmaalouf, May 2, 2012.
  1. karimmaalouf
    karimmaalouf TPF Noob!
    Apr 18, 2012
    13
    Lebanon
    Hello,
    was wondering what would be the best 2 canon lenses to get for my newly acquired Canon 7d, regardless of budget...
    i mainly shoot outdoors, portraits, nature, occasional indoor...
    i am looking at those lenses:
    - one standard range (i.e. 18mm or 25mm to around 70mm)
    - one telephoto zoom ( i.e 70mm to either 200mm or 300 mm)
    any suggestions?
    thanks
  2. Mach0
    Mach0 TPF Supporters Supporting Member
    Oct 16, 2011
    2,616
    429
    203
    24-70 2.8 and 70-200 2.8. If the 24 end isnt wide enough Maybe the 16-35?
  3. Overread
    May 1, 2008
    23,766
    4,061
    UK - England
    Regardless of budget?
    Canon 70-200mm f2.8 IS L MII is the best you can get in that range (excluding primes and honestly its darn close in quality to them). Couple that with a 1.4TC and 2*TC for nature work (depending on how much reach you want and what you define as "nature"). A 1.4Tc would be pretty standard for normal use as well, a little more reach with almost no loss of performance.
    Shorter I can't specifically say - 24-70mm f2.8 is common and there is a MII of that out sometime this year (very high cost). However for the crop sensor there are a few other options to consider if you want a wide reach at the wide angle end (many find 24mm isn't quite enough for some situations on crop sensor).
  4. TheBiles
    TheBiles TPF Noob!
    Jul 13, 2010
    869
    69
    MCB Quantico
    Without a budget constraint, I'd hold out for the 24-70 Mark II later this year and go with the 16-35 Mark II right now. You won't have any corner softness problems thanks to the smaller sensor. Pair these guys with the 70-200 f/2.8 IS II, and you're good to go.
    However, if you have such a deep pocket, why not get the 5D Mark III? It creams the 7D in every way.
  5. o hey tyler
    o hey tyler Been spending a lot of time on here!
    Aug 3, 2009
    9,782
    2,722
    Maine
    Because good glass trumps a good body. A 5D3 is next to useless if they don't have solid glass to put in front of the sensor.
  6. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Why limited to 2 lenses?
  7. karimmaalouf
    Apr 18, 2012
    13
    Lebanon
    thanks for your feedback guys, answers:
    - @TheBiles: "why not get the 5D Mark III": i've been saving to buy a high end camera but received as a present the 7d. From the reviews i read, it seems to be an excellent camera, so i am gonna keep it and invest the saved money in lenses. and i don't have a "a deep pocket" :) i just consider since i'm going to buy a lens, let me buy the best... (get one very good, instead of 2 average lenses... the second one will come later...)
    - @overhead: "1.4TC and 2*TC " i am sorry i don't know what are these... can you give me model numbers i can look up plz?
    - @Dao: "Why limited to 2 lenses?" i don't understand....clarify your thoughts please... i'm not gonna buy 20 lenses lol...
  8. Overread
    May 1, 2008
    23,766
    4,061
    UK - England
    No problem - TC stands for teleconverter - the 1.4Teleconverter from Canon has two versions, the newer MIII and the older MII on the market (the much older MI versions are still out there, but are not the best investment now). The 2* teleconverter, likewise, sold in MII and MIII versions.
    The MIII are the superior, though in the case of the 1.4TC the difference is very minor and even the 2*TC the differences are not night and day. The big advantage of the MIII over the MII is improved AF performance, but only with select supertelephoto lenses which start with the 300mm f2.8 IS L MII and longer newer lenses.
    Lenses should not be bought because they are "good"; instead they should be bought because they fill a specific requirement and shooting style of the photographer using them. Starting out this can be hard to discern because the criteria require real world experience to sort through. However a better way to go about lens purchases and lets one build a system around what they need, not just around generalist tools.
  9. ipschoser1
    ipschoser1 TPF Noob!
    Sep 17, 2007
    42
    EF-S17-55 f/2.8 IS, EF70-200 f/4L IS
    These two are standouts. Both produce amazing results.
  10. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,334
    Way up North in Michigan
    IF OP HAS DEEP POCKETS.
  11. Buckster
    Sep 14, 2009
    6,399
    2,334
    When I need W I D E on a crop sensor (my 7D or 40D), I reach for my 10-22mm.
  12. Dubaiian
    Dubaiian TPF Noob!
    Mar 11, 2012
    184
    18
    Dubai, United Arab Emirates
    I love my 10-22 on my 7D. A great lens for the money.
best canon 7d lenses
best lens for canon 7d
best lens to get for nature pictures canon 7d
best two canon lenses
can the canon 7d take advantage of high end lens
canon 7d lens
essential lenses for canon 7d
how to get the best portrait with my canon 7d
two best lenses for canon 7d
what lens best for 7d
