best 35mm camera??
Discussion in 'Photography Equipment & Products' started by reds_21, Sep 21, 2007.
  1. reds_21
    reds_21 TPF Noob!
    Sep 18, 2007
    10
    Cincinnati, Ohio
    I am possibly thinking of buying a new 35mm camera. i do not want to go towards digital. can anyone give me some ideas on 35mm cameras that are awesome for the price and that wont break in a month due to poor quality.
    im looking maybe no more than $300. is there a lot out there in this price range?? manufacturer's/model # would be appreciated!!!! personal reviews would be great as well :D
    thank you
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I bought my N80 off of craigslist for $100 like new.
    It's basically a slow, plastic F100 with a flash.
  3. sothoth
    sothoth TPF Noob!
    Jul 6, 2006
    250
    I bought a Canon A2 at KEH.com. It was used but it was in nearly perfect condition for under $200. I used a Pentax SLR for years but got the Canon so it would take all the EOS lenses I bought for my dSLR (thus not forcing me to take two sets of lenses everywhere if I wanted to do film and digital). So far, I'm VERY happy with the A2. The multiframe shooting is very smooth, the controls are simple, the body is light and well made (although I'm not so sure I like plastic bodies, at least they don't rust since I live near the ocean and have major corrosion problems with my equipment), and the image quality is very nice.
    My only complaint about the A2 is that the light meter ONLY tells you if you're exposing "correctly," or if you're under or over exposed, but it's not quite as easy to determine when you're at a full stop above or below the "correct" exposure. This is annoying to me because it adjusts in fractions of a stop, so you have to do some math in your head to know exactly where to set it if you want to go up/down in full stop increments. That's tough for my feeble mind when I'm trying to bracket in a pinch.
    If I were buying a 35mm camera (SLR or P&S) I'd definately go look at the used market, like from KEH or B&H or something, and not waste money on new stuff. The used market is an awesome way to get really nice film equipment for very cheap now, but make sure you go through a reputable online seller.
    Good luck!
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    Older but still good manual cameras that come to mind:
    Canon AE-1
    Pentax MX
    Pentax ME
    Newer AF camera bodies that I can recommend:
    Canon Elan II or even a 7
  5. Mike_E
    Jan 26, 2007
    5,327
    266
    Nikon N90s (magnesium alloy body, 4.3 FPS and takes AA batteries) with a new f1.8 50mm AF-D lens and an Sb-24, 25, 26 or 28 flash. All of this should run you around $300.
    After that get a 70-210mm f4-5.6 (should be under $100 used) and a 28mm f2.8 AI-S ($100-$150 used) [this is manual focus but with the DOF isn't a problem- look up hyper-focal distance].
    With this rig you'll be set up for as long as they make 35mm film. An F100 is nice too but they are running around $300 by themselves and the only real difference is just a tad faster auto-focus. (the battery issue -which they use- is a concern because you can't always get the CR-123s when your camera runs dry and if you have batteries for your flash you will have them for your camera ;)- CR-123s are also a lot more expensive)
  6. Lol999
    Lol999 TPF Noob!
    Nov 8, 2005
    316
    Chesterfield, Derbyshire, England
    Get a Nikon F3. Doable for $300 s/h. Bomb proof and a PROPER camera.
    Lol
  7. Mike_E
    Jan 26, 2007
    5,327
    266
    Did I mention a scanner that does film negs? You can develop B&W negs and scan them yourself if you like for a fraction of the cost. {color too if you can follow directions to the letter} Then send the files off to be printed as usual. ( hardly anyone actually uses a wet darkroom anymore so digital printing is all you are likely to get with out a search.)
  8. reds_21
    reds_21 TPF Noob!
    Sep 18, 2007
    10
    Cincinnati, Ohio
    thank you everyone that has responded!!!!!!
    im noticing Nikon is very popular, are they the leading manufacturer's in camera's? how do they compare to canon and minolta? are there manufacturer's that i should stay away from?
  9. Mike_E
    Jan 26, 2007
    5,327
    266
    Nikon and Canon were the leaders in Professional film cameras in the 35mm format. Which means that they had the biggest selection of lenses and 'stuff'.
    Minolta, Pentax were I think next in line followed by the others in popularity.
    The thing you'll want to remember is that just the camera body won't do you much good, it's all of the accessories and lenses that you get to go along with it that make an SLR desirable.
    Nikon, at least the newer auto-focus ones, will give you the most selection followed by Canon (Canon switched lens mounts and not all of their lenses will fit onto all of their cameras).
    I own an N90s, an N8008 (another great camera), an N70 (takes great photos and has nice "do-dads" but is a pain to shoot). I also have a Minolta that I learned on and still love along with various otherdigital and film cameras and if I were to keep just one film camera it would be the N90s for the quality of the camera and it's overall abilities.
    If your budget is $300 then I wouldn't suggest spending more than $100-$125 on the camera because you will still need a lens and a flash (yes, you will ;))
  10. reds_21
    reds_21 TPF Noob!
    Sep 18, 2007
    10
    Cincinnati, Ohio
    thanks MIKE_E.
    since i am not fimiliar with the camera world and the prices to go along with it, i was giving myself a budget of $300 just for the camera. i am seeing alot of options for lenses/flash's but i will look more into that later depending if i decide to stick with her Minolts x370s or whether or not i buy a new camera.
    by the sounds of it, i could get a really nice camera for $300 or less (not including accessories)
  11. Lol999
    Lol999 TPF Noob!
    Nov 8, 2005
    316
    A lot depends on what you want to do photographically. When I came back into it I bought a Nikon F301. It has full program modes, aperture priority and manual along with TTL flash and built in motorwind. You can pick them up for about $100 off e-bay and are bombproof. The only disadvantage it has is the motorwind, which being a street photographer can be a bit of a give away! Hence, I bought the F3. i still use the F301 when I have any flash stuff to do or if say I'm photographing a kid's party and need to respond quickly.
    Cheers, Lol
  12. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    1970s Nikon FE. They were unbreakable. Best camera ever! Did everything I wanted it to. Had aperture priority centre weighted metering, and a shutter button. What more could you want :)
    Even with all the fancy new things the modern cameras do I still run my D200 in Aperture priority mode with the same centre weighted pattern 90% of the time.
