Best 70-200 lens for Nikon mount?
Discussion in 'Photography Equipment & Products' started by Live_free, Apr 21, 2010.
  1. Live_free
    Live_free TPF Noob!
    Dec 25, 2009
    601
    7
    Washington
    Hey everyone I'm in the market for a new lens and as I want to shoot sports I've been looking into 70-200 lenses. Any recommendations? I'd buy either sigma or Nikon made lenses. Thanks all. If you have any you could post a sample pic you've taken with it, that would help a load. Thanks all.
  2. Josh220
    Josh220 No longer a newbie, moving up!
    May 23, 2009
    1,730
    83
    California
    Sigma has a few "gems" out there but their 70-200 is not one of them. Go for the Nikon; you can still get the VRI new from B&H if you want to save $350. I'm getting the VRII :D
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,252
    15,112
    USA
    Nikon, all the way. Either the first generation or second generation model.
  4. Josh220
    May 23, 2009
    1,730
    83
    California
    I take back what I said about finding the VRI on B&H. Last night they still had it listed, but now it's labeled as discontinued.
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Define best. Best in it's class, or best for you? Do you need VR? What about max reproduction ratio?
    The Nikkor AF-S 70-200 f/2.8 G VR II is about as good as it gets, but I'd be dammed if I'm going to pay the premium for that lens over the Nikkor AF 80-200 f/2.8D which will probably look optically the same on the pictures I take.
  6. Live_free
    Live_free TPF Noob!
    Dec 25, 2009
    601
    7
    Washington
    I just looked at the VR II and I must say I just can't justify paying 2.2k for a lens.
  7. D-B-J
    D-B-J Been spending a lot of time on here!
    Apr 13, 2010
    9,027
    2,172
    I want some pro glass, but there is no way i can afford some of those. So i plan on getting the nikon 80-200 2.8 AF-D, the two ring one. You can pick it up used for about 900, and new for 1100. Seems pretty reasonable to me, compared the the 70-200. Its still pro glass, right?
  8. Derrel
    Jul 23, 2009
    40,252
    15,112
    USA
    If you want a lens for sports shooting, you truly want a Nikon-made, genuine AF-S lens, that conforms to all Nikon focusing protocols, on all bodies. The difference between an 80-200 AF-D and an 80-200 AF-S (made only for a short time) and the two 70-200 AF-S models is that with an AF-S lens, the focusing distance can be calculated by the focusing system with incredible precision; with all the AF-D lenses, the focusing system uses an "adjust-and-compare,repeatedly" system of arriving at the right focusing point; with AF-S, the exact focusing distance needed can be predicted by the computer,and the in-lens focusing motor will drive the lens almost to the **EXACT** point of focus,using predictive focusing information--which is not how the AF-D lenses focus. On the lower-end Nikon bodies, like the D200 and D90, AF-D lenses have a decidedly slower focusing action than on the D1-D2-D3-D700 series, which have a better in-body focusing motor. On the lower-level Nikon bodies, an AF-D lens is at a decided disadvantage compared with the same AF-D lens on a top-tier body, and the lower-end and mid-range Nikon bodies benefit a lot from an AF-S lens. For any rapidly-moving subjects, an AF-S 70-200 will outperform the slower, non-predictive AF-D focusing lenses, especially under challenging focusing situations. There is also the lack of manual focusing override with an AF-D lens, and the need to manually disengage AF in order to do even a minor AF override with an AF-D lens.
  9. D-B-J
    Apr 13, 2010
    9,027
    2,172
    ^^ Thank you for that. I didnt know that, and that is interesting to learn.
  10. D-B-J
    Apr 13, 2010
    9,027
    2,172
    Disregard, i reread the ending of ur post. Haha.
    And, which is better for a "lower end" body, such as my D200, or the OP's D90. From what you said, im guessing it would be the AF-S. Is there a significant enough difference between the two to make it worth the extra 200?
  11. Derrel
    Jul 23, 2009
    40,252
    15,112
    USA
    I think the pro-level AF-S Nikkor lenses are worth the additional cost. I have owned two of the 80-200 screwdriver-focusing lenses and also the 70-200 AF-S, the original model. There's nothing faster than a good, pro-level AF-S Nikkor lens when it comes to focusing speed and sureness, especially when you want to shoot action shots. With an AF-D lens, if the lens mis-focuses a bit, you have to disengage the AF system just to touch up the focus...with an AF-S lens, there is full-time manuakl focusing override on all of the "pro-level" AF-S lenses; Nikon's AF-S protocol has two levels; the "pro" AF-S lenses all have the original AF-S system with full time manual focusing override. A small sub-set of Nikkor lenses, like the really cheap, newest kit zooms that call themselves AF-S have an A/M switch and do not offer full-time manual focusing override.
    I don't mean to describe the D200 as low-end, but it was the last of the mid-level bodies that had the amateur/pro AF system distinction/differentiation: the D300 in 2007 was the first mid-priced Nikon to offer the top-level AF module (the 51-point AF module also used in the D3 and D700), while the D200 used the simpler, 11-area AF system, and also the D200 and other lower-level Nikons simply do not have the big, beefy AF motors and huge battery capacity of the $5,000 D1-D2-D3 series bodies...
    The fastest and easiest way to beef up the AF capability of a lower-end Nikon like a D50,D70,D80,D90,D100,Fuji S2, Fuji S5,D40,D60, is to slap a pro-grade AF-S Nikkor on there. On the Nikon big glass like the 70-200 VR, 200mm f/2, and 300/2.8 AFS-II or newer, the LENS ITSELF has a huge focusing advantage over any of the older AF-D lenses in terms of focusing speed, sureness, and the ability to simply touch up the focus, without the need to press a button and turn a ring, or to flip an A/M switch. The older screwdriver focusing lenses simply do not focus the same way as the new AF-S pro-level lenses; it's possible for those who have only new Nikon lower-level AF-S zooms to be unfamiliar with the full-time manual focusing override design of the older AF-S lenses and the new pro-level AF-S lenses. For a user who has only the 18-55 or the 55-200 kit, they might be unaware of how the older, and pro-level zooms offer FTM and also much faster, surer AF than the low-cost, slower-speed and newest kit zooms with this new cheapened AF-S system that relies on an A/M switch.
  12. jeph
    jeph TPF Noob!
    Jul 7, 2008
    116
    Sunny San Diego
    Well I don't have any of this technical know-how but I do know that I rented a 70-200 VRII to go to an indy car race and after that experience I had to buy it. By the time that I uploaded the pics the quality went down but at 100% crop on my computer it is as sharp as I could want. Oh and the focus is stupid fast and right on.
    [​IMG]
best lens 70-200
nikon mount 70-200 best buy
