BEST CANON LENS FOR ACTION SPORT PHOTOGRAPHY
Discussion in 'Canon Lenses' started by Parko008, May 6, 2017.
  1. Parko008
    Parko008 TPF Noob!
    May 6, 2017
    16
    thanks for that pic. So from what i have been reading they say i should use either TV or Av mode which is ok but i am not sure as to what i then need to have all the settings on as in ISO the shutter speed i need as fast as possible as i am shooting athletics which are fast moving so any suggestions on what i should set it to in the day time???
    also have been fiddling with it at night whilst athletes are training well i have given up i cant get a single shot that is not blurry even shooting with shutter speed at 1/8000 i have changed settings so much that i dont know what is what anymore and ended up restoring the camera back to factory settings as nothing seem to work for it.....
    so i guess i will start with day first and get that right cause i have given up on night time very frustrating.....
    Thanks for everyones help learnt alot
    :1247:
  2. Vtec44
    Vtec44 Been spending a lot of time on here!
    Nov 13, 2008
    3,240
    1,524
    So Cal
    Manual mode, 1/400, 70-200 at 200.
  3. Overread
    May 1, 2008
    24,062
    4,171
    UK - England
    Few thoughts:
    1) TV is good for fixing your shutter speed; that's great for a photo like what Vtec just posted above of the motorbike where you want a slow enough shutter speed to blur the motion of the wheels; but fast enough to keep the action sharp over the body of the bike.
    Yes Vtec used manual mode but manual or TV would work.
    3) For general sports I would go with aperture priority mode. This lets you fix the aperture, ergo the depth of field. The shutter speed can then be as fast or as slow as it wants based on the light; so you keep an eye on it and if you need it faster you up the ISO and/or widen the aperture. This means you only need to keep an eye on the shutter speed - as long as its coming in faster than you need (say at least over 1/620sec) then you don't need to change anything.
    • Agree Agree x 1
  4. beagle100
    beagle100 No longer a newbie, moving up!
    Mar 31, 2015
    1,812
    444
    OK, I usually shoot in manual where I can control aperture and shutter
    www.flickr.com/photos/mmirrorless
  5. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    The best lens is the one that gets the job done the way you want to. With that said and your budget I would concur with the 70-200 f2.8. MkII if possible. If not the Mk I is still a very good lens.
    As for shooting, if you don't feel comfortable in manual then Overread nailed it, shoot in AV mode and use your ISO to keep your shutter speed up. You don't have to go crazy on shutter speed either. The age of the participants and the sport will determine your minimum shutter speed. You don't need crazy fast shutter speeds to freeze action, in fact crazy fast depending on the conditions will cause other issues.
    For young kids generally 1/25oth is fine. Older kids (high school on up) then you will generally want 1/500th minimum. I say Generally because if you are shooting curling 1/100th is fast enough. Certain motor sports you may want 1/1000th depending on the shot.
    I suspect that your blurring issues have to do with focus not shutter speed. Set you camera to a single focus point. With the 60 D having 9 focus points select the center point as it has cross type points and the Center point is the most sensitive. Set your focus point to continuous focus, AI Servo mode. Continually follow the action focusing all the time and be prepared to capture the action you want. Shoot as wide open as you can. Your DOF needs to only be as deep as necessary to capture the action. The difference between a good sports photo and a sports snapshot is making the action pop. That is done with a shallow DOF.
    Know the sport and the players so you can anticipate the action and always be prepared. Do not rely on spray and pray. While I generally have my bodies set in continuous mode I am light and quick on the shutter and only shoot a sequence when it really calls for it. That is generally action that is running parallel to me. Modern AF is very good, but still not as good as the human eye.
    Lastly practice, practice practice. The athletes have to practice and so does the sports shooter. Good luck.
which canon lens is best for action photos
