Best Diffuser Canon 430 EX
Discussion in 'General Shop Talk' started by Motley99, Jan 10, 2008.
  1. Motley99
    Motley99 TPF Noob!
    Jan 10, 2008
    5
    I am trying to figure out what way to go for a diffuser before purchase. I have seen some work with Fong but not much with a simple cap. I am new to wedding work (as I have been thrown to the wolves) and I am looking to get the best shots of course. How will each technology (Fong vs. Cap) be effected with a bracket also?
    PS - examples would be great!
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    the sto-fen is not that great....it's ok...
    The lightsphere is pretty sick.
    But, a lot of wedding togs just use a bouncecard...
    Also, it's a good idea to use more than one flash for certain situations...
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I'm not even kidding when I say 8 1/2 x 11 piece of paper.
  4. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    Unless you are using a custom bracket (swingable), you wouldn't be able to use the Fong Dong.
    Some people love the Lightshere, and some hate it.
    I have the Lightshere, the stofen (amber and white), and even a softbox. Normally I just use my white stoffen. It's the easiest.
  5. nicfargo
    nicfargo TPF Noob!
    Jan 4, 2008
    369
    Nebraska
    Elsaspet,
    What do you feels gives you the best results though...You say the Stofen is the easiest, but how does the Lightsphere compare. I'm looking at getting the lightsphere...but if it's not better then my Stofen, what's the point right?
  6. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    Because I shoot with my flash backwards, the stoffen helps me put light camera forward. It's just what works best for the crazy way I shoot.
    The lightshere does the same type thing, but for bouncing. The lightshere works well for a whole lot of people.
    The bad thing, is that it has a problem with falling off....but so does my stoffen. If you tape it on, that should get rid of that problem.
    The worst part is, if you use a Lightshere, you have to use a much more expensive and cumbersome bracket. (If you use one. I don't, but hubby does).
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    There are plenty of different flash accesories...they each work better or worse in different scenarios. The 'Fong Dong' for example, spreads light in all directions, with the intention that it will bounce off of walls and ceiling, thus giving you are light that surrounds your subject. That's all well and good if you have walls and a ceiling that are nice and close for each shot. If not, the light is just sent out, which means wasted light...which means faster battery consumption and slower recharge times.
    Many of the accessories are meant to help when you are bouncing the light off of a ceiling (or wall)...and they throw some light forward as fill. The Omnibounce, is an example of this. It's meant to be used with the flash at an angle so that you are bouncing most of it off of something...but it also throws some forward to fill in shadows that the bounced light won't get (also helps for catch lights).
    A simple bounce card will do exactly the same thing.
    I often see photographers put the omnibouce on the flash and fire it directly at the subjects...thinking that the opaque plastic will make the light softer. This doesn't really work because the softness of the light is determined by the relative size of the light source compared to the subject...and the omnibounce isn't really much bigger than the flash head...so it's not really softer. It just wastes more light/power.
    You can get a softbox for the flash, which does increase the size of the source...which does make the light softer. These can be a bit of a pain to work with though.
    You also need to consider your camera orientation. A lot of shooting is done with the camera in vertical/portrait orientation, which puts the flash off to the side...this can create some bad looking shadows on things behind your subject. This is where you want a flash bracket to keep the flash above and in-line with the lens.
    There is no 'best' accessory or even the right one...you just need to find what works for you...but understanding light will go much, much farther than any accessory.
