Best interpolating/upsizing method?
Discussion in 'Beyond the Basics' started by elemental, Sep 9, 2009.
  1. elemental
    elemental TPF Noob!
    Feb 6, 2008
    646
    I'm going to be making a large print from a relatively small original (2592 x 2592 px crop from a D200 to a 36" x 36" print, or more exactly 54 4x6 prints that will be assembled into a 36x36- it's complicated but irrelevant). The actual resolution at that size is 72 dpi, which isn't exactly "high quality." I did a test print of a crop from the original at this resolution, and it does look good enough for the purpose, but I'd rather upsize it myself than let the machines at the print shop do it for me. I know there are different methods and algorithms to do this, so I'm wondering what has worked for people in the past. I have GIMP and Photoshop (and yeah, I prefer GIMP for most of what I do), and I'd be willing to try other software as long as it's free. It's really not worth going out and buying something for.
    The picture, if you're interested:
    [​IMG]
    I wanted something ghetto for my apartment, and this was (a) the right color range, (b) square and (c) had some hope of getting to 36 x 36 (sorry 35mm).
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    For upscaling I think GIMP's Lanczos filter is better than anything Photoshop has to offer, but then one thing that is critical here is that you have a lot of smooth gradients rather than fine detail. This means you probably won't notice a difference between Lanczos or Bicubic.
    The last word in upscaling really is Genuine Fractals. This consistently provides far better large upscaling than anything else I've tried.
  3. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    Ditto. Genuine Fractals is just...freaky. Fantastic, but to the point of being freaky. A comp sci friend of mine calls it black magic. :lol:
  4. KmH
    Apr 9, 2009
    40,756
    5,588
    Iowa
    Based on recommendations from Scott Kelby and Vincent Versace, the landscape photographer, I use Adobe's algorithm, Bicubic Sharper to upsize.
  5. elemental
    elemental TPF Noob!
    Feb 6, 2008
    646
    Wow- based on the info gathered here and subsequent Googling, it sounds like Genuine Fractals really is the standard. Unfortunately, it's just not worth the price for this project. If I'm going to stay in the GIMP/PS realm, is it worth upsizing it myself or should I just send the files to Mpix at 72 dpi and let them handle it?
  6. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Here's an excellent series of comparisons between GF and PS:
    The Online Photographer: It's Bigger, But Is It Better?
    The Online Photographer: It's Bigger, But Is It Better? Part II
    The Online Photographer: It's Bigger, But Is It Better? Part III
    No one upsampling method is always the best. There are always trade-offs where one is better than another is some aspect but not the best when another attribute is considered. One this that is always important is to do noise reduction carefully before upsampling. Many upsampling methods can mistake noise for subject detail and try to create sharp edged "objects" out of a clump of noise.
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Printers don't normally upsize. If you send them a 72ppi image you will get 72 pixels per inch, and from a meter away quite clearly see distinct small pixel squares.
    It never hurts to upsize compared to printing standard. Fire up GIMP and up the res to 200ppi (should be way more than enough given the size of the final result)
  8. Moglex
    Moglex TPF Noob!
    Jun 13, 2008
    578
    Whitstable
    This is absolutely true.
    How would the printer know whether you were sending it a low resolution image or a post-pointilist image or some scientific visualisation?
    I had a God almighty argument with Bifurcator and HelenB on this subject a while back since they both swore blind that the printer was responsible for upsizing.
    (The exception is where the printer connect directly to the camera when it will know the provenance of image it's receiving and can thus make certain assumptions about it. Although whether it ever upsized would depend on the cropping selection criteria.)
  9. KmH
    Apr 9, 2009
    40,756
    5,588
    Iowa
    Mpix won't accept files at 75 ppi. They require a minimum of 100 ppi before they will print.
    If you want an 8x10 it has to be at least 800x1000 pixels which is 100 ppi.
    Here is Mpix's requirements.
  10. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    The best approach using Photoshop is to create an action which upscales the photo 10% and put it on a function key. By upscaling 10% at a time, you will lose absolutely minimum quality even at 12 times the 10% action.
    Try it. It works.
    skieur
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Oh my god, I remember that. I remember having a really heated debate with you on some similar printing issue which resulted with you on my ignore list for like half a year. Times are a changing :hug::
  12. elemental
    elemental TPF Noob!
    Feb 6, 2008
    646
    In my searching, I've heard this vehemently defended and flippantly discounted. The only way to know, of course, it to try it for myself. To give all of you an honest comparison as well, I'll upload 100% crops of both the one-shot upscale and the incremental upscale. Can you tell which is which?
    A:
    [​IMG]
    B:
    [​IMG]
gimp upscale
gimp upscale filter
gimp upsizing best scaling algorithm
image up scaling fractals algorithm
interpolated upsize
