Best Lens for outdoor motocross daylight
Discussion in 'Beyond the Basics' started by ottor, Apr 13, 2009.
  1. ottor
    ottor No longer a newbie, moving up!
    Feb 7, 2009
    935
    173
    S. Idaho
    I have a big MemDay motocross event - 3 days... I'd like to get a little better lens than I currently have... the standard Canon 70-300 cheapie... I can rent either,
    a Canon 70-200 f/2.8 L IS for $64.00 for 7 days ... or
    a Sigma 120-300 f/2.,8 APO HSM - $105 for 7 days...
    I'm using a Canon 450D. I'd be using a Monopod and an 8gig card. I have Track access, so I can get pretty close if needed... but the telephoto is needed also..
    Any ideas, or better suggestions?
    thanks,
  2. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    14,652
    2,749
    Wichita, Kansas, USA
    How close or far away from the action will you be? That would be one of the major deciding factors.
    If you are talking a bit of distance then I would suggest either the 300 f2.8 or 400 f2.8. More expensive to rent for sure and you don't need f2.8 in that bright of daylight, but I own both lenses and they are sharp enough to shave with.
    If you are pretty close to the action then my choice would be the 70-200. Again a very sharp lens.
  3. DRoberts
    DRoberts TPF Noob!
    Apr 18, 2008
    780
    Springfield, Missouri
    If you have track access the 70-200 will be fine. If it will be going into the nite under lights then get the 2.8 if it is all daytime you can get away with the 4. The difference may allow you to rent a prime to use against the track.
    One more thing...you might want to try hand held, motoX has alot of highspeed ups and downs that is sometimes a pain to follow with a mounted camera, tripod or mono.
  4. ottor
    Feb 7, 2009
    935
    173
    S. Idaho
    I was thinking of panning, but you're right... My rig will be close-by, so I can trade off frequently... There will be areas where I can be totally safe, and yet only about 10' from a turn.. Shouldn't go into dusk or dark.. except perhaps the Trophy Presentatons.. :confused:
    Appreciate the feedback....
best camera for motocross
best camera for motocross pictures
best camera for taking motocross pictures
best canon lens for motocross
best lens for moto cross photography
best lens for motocross
best lens for motocross photography
best motocross lens
lens for motocross
what lens to use to shoot mx
