Best SLR for beginners
Discussion in 'Photography Beginners' Forum' started by cherry30, Oct 21, 2008.
  1. cherry30
    cherry30 TPF Noob!
    Oct 21, 2008
    138
    I am contemplating on buying an SLR that is inexpensive. What is the best one for me? Right now, I only have a digicam that has been with me for 2 years now. Please point me in the right direction. Something cheap will suffice. Thanks.
  2. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    Canon AE-1, Solid film camera readilly available for under a hundred dollars.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Nikon FE, Solid film camera readilly available for under a hundred dollars.
  4. Senor Hound
    Senor Hound TPF Noob!
    Apr 23, 2008
    1,425
    La la land...
    I'm going to assume you want a Digital SLR, and tell you to get a Sony a200. They're new, have a 18-70 lens, built in anti-shake, and all for the same price of a D40.
  5. EW1066
    EW1066 TPF Noob!
    Apr 4, 2008
    185
    4
    Santa Fe, Texas
    Pentax K1000. Auto nothing will teach you everything. Tough as nails and can be used as a weapon in a pinch......
    Vince
  6. debvath
    debvath TPF Noob!
    Sep 23, 2008
    22
    I bought a used sony a100. I had to send it in because the shutter was sticking every once in a while. I wanted it fixed before it got worse. In the meantime I borrowed a nikon d70 from the camera shop.
    I have to say I like mine so much better.
    I didn't know the camera shop rented cameras out. Maybe that is one way to see what you like. I don't know how expensive it is to rent them though. I got to use it for free since mine was being worked on.
  7. cherry30
    cherry30 TPF Noob!
    Oct 21, 2008
    138
    Wow! Your response got me confused. LOL. I got five different kinds from 5 replies. I have to check them one by one to see what will fit me best. THANK YOU so much.
  8. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    You got such varied replies because your question was very general. Can you give any more details? Do you want digital or film? What kind of things do you like to shoot? What is your experience level and how seriously do you want to take photography? Do you have a budget in mind?
  9. mrcrassic
    mrcrassic TPF Noob!
    Oct 7, 2008
    52
    Brooklyn, NY
    Do you want a film SLR or a digital SLR? Keep in mind that both of them will help you learn a lot about photography, though one may be more harsh to your mistakes than the other. :p
    I use Canon equipment, and know little about Nikon. Thus, if you're looking at film, anything under the Canon 1 series will be cheap for you to come by (think less than $250). For digital SLRs, it really depends on your budget. If you look hard, you can find a Canon 40D for less than $800 and a 20D for less than $400.
    If you can afford it, I would recommend starting with a "prosumer" camera like the Canon 20D, 30D and 40D. The 10D uses antiquated technology, but is cheap to obtain and well-built all the same. If you want to go even cheaper, you can pick up a 300D, a lightweight 10D, for $200 or so (with the stock lens). It's all plastic, so it's lightweight, but it's designed very well (I dropped it from a few feet, and it survived!).
    Good luck!
  10. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    For digital I'd recommend buying a used nikon d70 outfit off ebay.
    For Film, you can't go wrong with an f100.
  11. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Please people get details from OP on what their budget is, what they like, if they have any other equipment, if they have friends (who may loan them stuff) that have a certain type, etc. before responding.
    Without that info I could recommend everything from a Canon Rebel XTi to a Nikon D3 and be well within acceptable.
  12. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    I would not recommend a film SLR for many reasons. One being that there is no instant gratification. You cannot see your photos after you take them, which means you cannot correct mistakes. Also, unless you can get a darkroom and all the required chemicles, processing will be immensely expensive, and you will have paid for a DSLR withing a month or two.
    As for DSLRs, I would reccomend a Nikon D70s. It has a built in AF motor, and is great to grow into. The D40 would be the ultimate beginner body because of how easy it is to use, however it has some major flaws, such as no aperture dial and lack of in body AF motor. The D70s may not be as glamorous as the D40, however if you are more serious about photography and want a better camera for slightly more money, I would go with the D70s.
    The D70s body will go for about $350, which is as cheap as its gonna get for a DSLR.
best beginner film slr
best film slr for beginner
best film slr for beginners
