Best Tripod Head for Pano
Discussion in 'Photography Equipment & Products' started by Soda Ant, Dec 12, 2008.
  1. Soda Ant
    Soda Ant TPF Noob!
    Dec 3, 2008
    14
    I'd like take some panoramic shots with my DSLR and stitch them together in Photoshop.
    I will eventually buy a dedicated pano head such as a Nodal Ninja, but for now I'd like to keep things simple and use a general purpose head. I have a Manfrotto 3221 tripod--what kind of head, 3-way pan head or ball head, is best suited for pano work?
    Any recommendations as to model/brand? My budget is around $150-200 max (I'd like to keep it closer to $150) and it needs to support a DSLR and lens weighing around 5 pounds.
  2. Overread
    May 1, 2008
    23,206
    3,830
    UK - England
    3 way pan head. A ball head is not as good since only the expensive ones allow you to selectivly release pressure in one axis - most when you release pressure on the ball you release it for the whole surface - so there is a big chance that when panning side to side your vertical will also be changing.
    A 2 way pan head will have a panning plate which will be on its own pressure release - so you can release pressure in that axis alone. There are dedicated panning plates as well which would combine well with a ballhead and allow paning, but its a more expensive rout and since your going for dedicated kit get the 3way
    As for a model I can't advise - just go for the best you can afford :) Manfrotto heads are a solid investment too
  3. Soda Ant
    Soda Ant TPF Noob!
    Dec 3, 2008
    14
  4. Overread
    May 1, 2008
    23,206
    3,830
    UK - England
    yep that would work - if what you want is a ballhead with pano.
    If your major interest is going to be landscapes, buildings, pano ect type subjects then chances are a 3 way is better/
    but if your just branching out and want something more general and flexable then that looks to be a good choice
  5. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    11,534
    2,119
    Wichita, Kansas, USA
best ball head for panorama
best panoramic ball head
best tripod for dslr panoramic
best tripod for panning
best tripod head for dslr
best tripod head for panning
best tripod head for panoramic shots
best tripods for panning
good tripod for panning
pano-maxx tripodhead, pano head
