Best way to clean mirror on a DSLR?
Discussion in 'Photography Beginners' Forum' started by Igaryok, Jan 4, 2007.
  1. Igaryok
    Igaryok TPF Noob!
    Dec 27, 2006
    Hi,
    I'm sure this questions has been asked many times before, but I have a Nikon D50 and whenever I look into the viewfinder there's a black speck which I assume is dust on the mirror, that got there when I was putting on the lens? It doesn't show up on the pictures or at least I can't notice it. But what's the best way to clean the mirror? Thanks.
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    the best way to clean the mirror is not to clean it ;)
    if it is not too bad i would not bother, you will collect more spots on it with time. but since the mirror is out of the way when the picture is exposed, it does not matter.
    safe your efforts to keep your sensor clean :)
  3. Igaryok
    Igaryok TPF Noob!
    Dec 27, 2006
    thanks a lot. BTW the photos on your site are breathtaking. :hail:
  4. Big Mike
    Dec 16, 2003
    33,876
    1,826
    Edmonton
    Very carefully! :lol:
    As mentioned, the mirror has no bearing on image quality and is delicate...so only clean it if you have to. That being said, you could use a bulb blower or soft brush to gently clean the mirror. The spec may be in your viewfinder, however, which is harder to clean.
  5. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    This might be reading too far into the response but if you use a brush to clean the mirror is there any direction you should go? Like is the mirror more sensitive to being knocked out of alignment sideways so it would be smarter to brush it going vertically or vice versa?
    I would think if you're going to knock it out of alignment it would be to the side so maybe brushing it vertically will be a bit safer???
    I guess you could always use a vacuum cleaner with a small enough attachment. :wink:
  6. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    thanks for the nice comment :)
  7. Funky
    Funky TPF Noob!
    Sep 24, 2006
    374
    California
    Ummm i advise you to use some kind of air blower....using a brush always gives you the chance of accumulating little dust particals on the lens. i advise you to take it in to be cleaned.
  8. jcharcalla
    jcharcalla TPF Noob!
    Sep 3, 2005
    92
    You may want to check out this site because they had a good method to check for dust on your sensor itself.
    http://www.cleaningdigitalcameras.com/howto.html
    Towards the bottom is a section called "How To Create A Test Image
    To Check For Dust"
    If you think you need to clean your sensor you can do it yourself. I would stay away from any compressed air systems as they usually have some type of oil in the can. Squeeze blowers are fine but I had no luck with mine.
    I was able to clean the sensor on my 20D using Sensor Swab's and Eclipse cleaning fluid made by Photographic solutions. These products however are semi expensive but if you compare them to what it would cost if you went to a camera shop they are not that bad.
    If your sensor is clean though I would stay away from touching it.
  9. jcharcalla
    Sep 3, 2005
    92
    Haha I should learn to read.... :confused:
    Not sure why I didn't realize you were talking about the mirror. You could probably just use a blower on that but make sure you hold the camera upside down or something so the dust does not fall on your sensor.
  10. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    wow, what a word .. semi expensive ;)
  11. LifesMirror
    LifesMirror TPF Noob!
    Dec 28, 2006
    70
    Louisville,Ky
    I clean my slr mirror with a q-tip, just very, VERY lightly. And yes, the viewfinder is a $*@% to clean,lol.
clean dslr mirror
clean slr mirror
cleaning camera mirror
cleaning dslr mirror
dslr clean mirror
dslr mirror cleaning
dslr mirror cleaning kit
dust on dslr mirror
how to clean dslr mirror
how to clean the mirror on a dslr
