black backgrounds
Discussion in 'Photography Beginners' Forum' started by stang96mj, Feb 10, 2010.
  1. stang96mj
    stang96mj TPF Noob!
    Aug 3, 2009
    69
    Texas
    I don't really know how to ask this because I didn't want to just steal someones picture to put up here as an example...lol How do you get a black background to be so dark when taking the picture, not in photoshop? (when i turn it into black and white) Feel free to post a pic to show me if you are thinking of what i'm thinking...lol Thanks!!
  2. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    you mean something like this?
    [​IMG]
    If so then, just shot it against black background and then desaturated it. IF were to take it a step further, then I'd boost the contrast up a drop.
  3. K.Li
    K.Li TPF Noob!
    Dec 23, 2009
    83
    Australia
    i think you can also set up lights on the subject but stop the light from spilling onto background with flags to cut out the ambient light
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    The key to a black background, is to have less light reflecting off of the background, than off of the subject. You obviously need to set your exposure for the lighting on your subject...you will then want the background to be at least 2.5 stops darker.
    This doesn't mean that your background has to be black to start with, it can be white...it just has to be darker than your subject. You can create this by ensuring that the light you have on your subject, is not getting onto the background. One of the most basic ways of doing this, is to have the background be as far away (from the lights) while having the subject much closer to the lights. Another trick is to use 'flags' (something between the light and where you don't want it to go), but it also helps to use things like grids & barn doors on the lights, to keep them constrained to where you want the light.
    Of course, using a surface that absorbs a lot of light, rather than reflects it, is helpful. Black velvet, for example, eats a whole lot of light.
  5. stang96mj
    stang96mj TPF Noob!
    Aug 3, 2009
    69
    Texas
    How would I use flags? And how would I use grids or barn doors? Sorry not THAT knowledgeable in Photography yet...LOL
  6. stang96mj
    stang96mj TPF Noob!
    Aug 3, 2009
    69
    Texas
    Yes, like this. I am wanting to do some by the window with natural light.
  7. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    I would think that would be somewhat difficult.
    As was mentioned earlier the easiest ways are using the following method.
    1. the subject is as far from the background as possible
    2. the subject is as close to the lights as possible (the lights sort of have a DOF, meaning that if they are close to the subject the light falls off quickly, and if they are farther from the subject the light falls off slowly and thus inhibits the background).
    3. Use of flags etc. to block the excess light from hitting the background.
    If you are using window light the struggle will be that the light is coming from a distance and will thus not fall off quickly. It is still possible, though, again, it is much easier with your own lighting.
    As Big Mike suggested in this case your best bet would probably be to have a non-reflective background (such as black velvet) at a distance from the subject and as far from the light source (window) as possible. It won't necessarily work perfectly, but it's a start. And if you get it close, some play in LR/PS with curves should get it the rest of the way.
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    But not impossible.
    [​IMG]
    This was shot with window light, which you can see was off to the left side some.
    The background was far enough back that it was substantially darker.
  9. NateWagner
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    absolutely, not impossible. Just more difficult.
  10. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Yeah (wasn't trying to imply that you said it couldn't be done).
    Doing this with window light, it would help a lot to be able to block off some of the light.
    In my case, the shape of the room I was shooting in did it for me.
    Totally awesome drawing made with the most state-of-the-art drafting software:
    [​IMG]
    Edit
    Damn, I forgot to put a red ring on the lens... Oh well, just imagine it - this kick-ass drafting software takes forever to load...
  11. NateWagner
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    yeah, kind of like built in flags. Would definitely do the trick.
