black spot on photo
Discussion in 'Photography Beginners' Forum' started by jkleinhe, Feb 27, 2009.
  1. jkleinhe
    jkleinhe TPF Noob!
    Feb 27, 2009
    17
    State Road, NC
    Every time I try and get close to a subject and my flash goes off I get this dark, half moon shape at the bottom of all my pictures that ruins my shots. Does anyone know what is causing this? I am using a nikon D40 and my lens is an 18-200MM. It is almost like my flash is casting the shadow. Has anyone else had this problem? Below is a link to an example picture.
    http://i591.photobucket.com/albums/ss359/jkleinhe12/DSC_1394.jpg
  2. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    That's the shadow from the lens...it's because you're using the pop-up flash and the lens is long.
  3. jkleinhe
    jkleinhe TPF Noob!
    Feb 27, 2009
    17
    State Road, NC
    That is what I thought, is there any way to avoid this? If I bought an external flash unit would this help me avoid this problem or should I just get a different lens (macro) when trying to take such close shots?
  4. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    yes, the external flash will prevent it.. you should never use a pop up flash.. as they such.. always use an external flash
  5. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Yes. The external flash is up higher above the lens and unless you're really close and using a huge lens you shouldn't get the dark semi-circular shadow.
    Or you can use the flash off-camera and not have to worry about lens shadow ever again. Plus you get better quality of light because you're not foward firing the flash. For more info: Strobist.
    You still would need to light the shot and being closer would make the lens shadow even worse. For macro shots you could use something like this, or use the external Speedlite off-camera (strobist).
black spot on my photo
black spots in photos
dark spot at the bottom of the picture
how do you mark on pictures from a nikon d40
how do you prevent dark spot camera flash
i get a shadow at the bottom of each picture using nikon d5000
in photograpy causes of black spot in the middle bottom of picture
what causes a black spot on my pictures
what causes black spots on my nikon photos
why does my photo have a dark mark on the bottom half?
