blackened out background?
Discussion in 'Beyond the Basics' started by Terri Walsh, Jul 29, 2008.
  1. Terri Walsh
    Terri Walsh TPF Noob!
    Sep 19, 2007
    187
    Calgary, Alberta
    I am wondering how people get those beautiful newborn shots (especially) with the blacked out background?
    Do I NEED a black background?
    What is a likely ISO range for indoor newborn shots with natural light? (obviously depends on the amount of light but I was surprised to hear people going up to like 1600 ISO, would that not be too noisy?)
    Would my 50mm 1.4 be a good lens to use? (but at f/4 or something for clarity of the face?)
    Thanks in advance! :)
  2. K_Pugh
    K_Pugh No longer a newbie, moving up!
    Sep 26, 2005
    1,344
    75
    Scotland
    Never tried newborn photography myself. I think your 50mm lens would be perfect and yep a stop or two down from wide open should give you the sharpest results, might need a little more DOF though? depends what you're going for.
    I'd keep the ISO as low as you can. If you're using natural light, try being as close to a window as you can i would say.. this could/should? also help with keeping a darker/black background, plus keeping the background as far away as possible.. a reflector might come in handy as well.
    Don't know how easy it would be but you could use make shift Gobo's to block out light going to your background as well, if possible.
    You may even be able to under-expose a bit and bring the detail back out in PP?.
    Just some thoughts.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    black backgrounds are easy, just need to overpower the ambient with strobe.
    OR, you could get away with doing it with window light if you put curtains over the window to diffuse the sun, and use black velvet behind the subjects at a distance.
  4. Big Mike
    Dec 16, 2003
    33,830
    1,812
    Edmonton
    The key to a black background, is having more light on the subject than on the background. You can often do this by having the background farther away from the light, than the subject. Might be a little harder with window light.
    Using a light absorbing material will help, black velvet is ideal.
    Finishing it off in Photoshop (or similar) might also be required.
    As for the ISO and aperture to use...that all depends on the light. The key is to watch your shutter speed. You will probably need at least 1/60 to avoid camera shake blur...and if the subject is moving, you may need a higher speed. To get that speed, you might well have to use ISO 1600. Noise is better than blur. As long as you expose the image well, the noise shouldn't be too much of a problem, but if you underexpose the image, the noise will really stand out when you adjust it.
  5. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
  6. PattiS
    PattiS TPF Noob!
    Apr 13, 2008
    79
    I have some velvety black blankets (I think they are from JC Penney) that I use when I want a black background for newborns. I also highly recommend a macro lens for newborns- my most recent newborn session was shot almost entirely with my 60mm macro.
how to black backdrop infant photography
how to edit newborn backgrounds photos
how to get black background in photography
how to make a black background fpr my newborn shot in photoshop elements
how to shoot a picture with black background
how to take baby pictures with black background
how to take newborn photos with black background
how to take newbornnpics with solid nlack background
newborn photography black background
newborn photography with black background
