Blank processed film
Discussion in 'Photography Beginners' Forum' started by GraphicGuy, Oct 21, 2009.
  1. GraphicGuy
    GraphicGuy TPF Noob!
    Oct 12, 2009
    7
    York, PA
    If after the film is developed, (manually) the film comes out blank. The lens cap was not on and the film speed adjustment was right. Any comments or suggestions?
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    the film was not properly loaded so it didn't pass behind the shutter,
    if you developed the roll yourself, did you happen to use fixer first?
  3. milo_d
    milo_d TPF Noob!
    Oct 20, 2009
    49
    a blank film means that no shoots were made ... on my old 60s camera i use tape to positon the film...also i have learned that form manual develop there are special solutions ...i m not familiar with the process but my photolab guy said so ...you shoul talk to a pro and beg him to let you watch how it s done ...good luck
  4. GraphicGuy
    Oct 12, 2009
    7
    York, PA
    The film contained a few frames that had a faint image or just dark spots, but no image. It just seems like they are not getting the right exposure, however the light meter read that it was okay?
  5. milo_d
    milo_d TPF Noob!
    Oct 20, 2009
    49
    can you post a photo so that we can see what the problem is ...
  6. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    If a roll of film comes out blank, or has only the faintest traces of images, the first thing to look for is the edge print. Don't give any other evidence or memory of how the film was exposed any consideration until you've examined the edge print.
    The edge print is exposed onto the film during manufacture. It develops like a normal image. If is is not present or just as weak as the faint traces of images then the fault lies solely in the processing. If it developed completly, dark black numbers and text on negatives or clean white or slightly yellow on slides, then processing was reasonably correct and the problem lies elsewhere.
    What does the edge print look like??
  7. GraphicGuy
    Oct 12, 2009
    7
    York, PA
    The numbers come out fine on the sides. In fact, this last example actually contained about 4 decent images. The chemicals are all good. When I developed mine, they were fine. However, the other example came out mostly clear, with the exception of a few. There are some "black exposed spots on the film." I am going to try to scan or take pictures of them.
  8. GraphicGuy
    Oct 12, 2009
    7
    York, PA
    What is the best way of posting images? I could find a way to post them on the threads?
  9. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    It's possible that your meter is shot or yout batery is flat.
    *EDIT*
    Photobuket works just fine, upload them to PB and then post them here using the [​IMG]
blank developed film
exposed and processed film blank
photograph processed, film processed
what is blank developed film
when a roll of film develops and comes out empty
when printing films why do they come out blank
why film comes out blank
why processed film comes out white or blank?
why would film come out blank
