blowing up digital prints
Discussion in 'Beyond the Basics' started by spiffyandstuff, Oct 16, 2005.
  1. spiffyandstuff
    spiffyandstuff TPF Noob!
    Oct 16, 2005
    so when you blow film pictures up to big it doesn't really look that bad, the dots are just further apart... but digital looks awful when you blow it up, anyone know of any tricks around this? i've been messing with huge resolutions, 500+ dpi, then applying a 'halftone' filter, but i haven't been able to print anything out yet
    also, if i change the standard 72 dpi reolution to 300 dpi without changing the print size, will i get a better print?
  2. jadin
    jadin The Mad Hatter
    Feb 18, 2004
    1,740
    9
    Down the Rabbit Hole.
    There's a few things you can do. For starters the method of resampling you use can greatly affect the output quality. For example pixel resize will give a horrible outcome. Instead use something like bicubic, in Photoshop CS2 they have an option called bicubic-si which works even better than bicubic.
    You can use programs such as Genuine Fractals, a program that does nothing but resizing. It's results are quite nice. Many stock photography websites require you to use something like that for optimal results. I personally use Paint Shop Pro, which has an option called smart-size, I couldn't tell the difference between a Genuine fractals resize or one inside using smart-size, so I simply use that.
    Lastly you can resize slowly. For example resize your photo just 10% larger at a time. This will help you to keep the detail that can be lost by simply resizing to your desired size. This works especially well when you use one of the better resample methods listed above.
    I don't think so, but don't quote me on that. If I remember right if you change the dpi resolution absolutely nothing about the photo will change. Only if you change the print size as well. I've found it's two different modes to work in, stick to what you find easier.
    One method is simply pixels. A 3000 width image can print up to 10 inches at 300 dpi, or 20 inches at 150 dpi. You do the math in your head and it's pretty straight forward.
    The other is strictly based on your desired print size. If you want to print at 300dpi and want an 8 x 10, it will resize the photo to 3000 pixels. I find the only time this method is useful is if I'm printing something like a postcard something that has to be exact dimentions.
  3. alexecho
    alexecho TPF Noob!
    Jun 8, 2005
    200
    DPI is dots (pixels) per inch, so more of them will give a better picture, surely? I think... Maybe... It also depends on the printer, they like a 300dpi image, and stretch pixels if the original is less, but don't quote me, either!
  4. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    If you are printing at 72 dpi, that is your problem. Photo quality prints should be at 300 dpi. From there it's the same with film. The size of your negative (megapixels) will determine how far you can enlarge and still retain detail.
  5. Marctwo
    Marctwo TPF Noob!
    Aug 19, 2005
    485
    10
    B'ham, UK
    It seems an awful lot of people get confused over this type of thing and I think a lot of it is to do with the way PS handles/presents the dpi in image size. You'll find it more simple if you think of resizing in two stages:
    1. Set the dpi: Most people would agree that 300dpi is pretty much standard so uncheck the resample image button in image size then set the dpi to 300. The pixel count and the image itself will remain unchanged but the software will now interpret each pixel as 1/300 of an inch in printing terms so the print size of the image will change.
    2. Interpolate the image: This is the part that actually changes the image and adds pixels - in other words, it resamples the image. In resize you can either enter the required size in inches/cm/mm/etc. or you can do the math yourself and enter the pixel size directly, eg. 10 inches X 300dpi = 3000 pixels. Remember that the resample image button must be checked for this stage.
    It's a good idea to include step 1 in a pre-processing action along with anything else that you initially do with all images.
  6. jadin
    Feb 18, 2004
    1,740
    9
    That's what that little resample button is for! It makes so much more sense now! Thanks. :sillysmi:
    :hail::hail:
  7. Marctwo
    Marctwo TPF Noob!
    Aug 19, 2005
    485
    10
    B'ham, UK
    I'm happy to help. :D
  8. fdi
    fdi TPF Noob!
    Aug 14, 2005
    5
    Dallas
    I use Qimage to res up my images before printing. I use to print great 13x19’s from my 3M D30. My favorite thing about Qimage is not having to store the res-ed up images which end up being enormously large 13x19 tiffs. Even if I do some mods during the printing Qimage just stores an attribute file so I can exactly reproduce the print later.
  9. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    Yeah what they said. Always keep in mind the original file size. Part of digi's appeal is the interpolation of pixels. Technology has made great strides in this field. Personally I try not to enlarge or reduce my photos by more then 20%. Also keep in that photos are enlarged not blown up.
  10. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    keep in mind, color film is equivalent to around a 16 megapixil image.
  11. jadin
    Feb 18, 2004
    1,740
    9
    Slight correction. 35mm film is around 16 megapixels. There's more than one size of film. ;)
  12. cbay
    cbay TPF Noob!
    Mar 13, 2005
    409
    Birmingham, UK
    Well i have just been experimenting with this as i didnt realise about the DPI, i printed a image off 10 x 8 @ 72dpi and it was rubbish changed the image to 300dpi and printed and it was exactly the same!
    Any ideas??
blow up 72 dpi
blow up prints
digital pic enhanced and blown up
how big can a 72dpi photo be blown up
how many dots per inch for a photo blown up to a3
resolution for blowing up pictures
what can a 72 dpi picture be blown up to
what happens to the resolution of a picture when it is blown up?
what matters when you blow up pics dpi or resolution
