Boom stand for a beast?
Discussion in 'Photography Equipment & Products' started by fadmission, Sep 7, 2010.
  1. fadmission
    fadmission TPF Noob!
    Sep 7, 2010
    I am planning to get a Mola Mantti 43.5" Softlight
    ME435 Mola Mantti 43.5" Softlight, Interior White Surface with PAD Diffuser, Unified Swivel Handle, & Exterior Nylon Diffuser
    and wanted to know what would be the best boom stand for a beast like that? The dish itself is 15lbs and including the 5lb Alien Bee light will total around 20lbs. So I'm looking for a boom stand (fully extended) to support at least 20lbs. Can anyone help me out with this?
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    39,638
    14,830
    USA
    Manfrotto's Heavy Duty Boom Stand with 15 lb. counterweight should be adequate.
  3. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    I think you're looking for a Century or C-Stand, Hollywood style. 20lbs is a lot. For that kind of weight, an air cushioned stand would be a priority for me.
    I have this one, but I'm not sure it will handle 20lbs at full extension, surely not without additional counterweights.
  4. Derrel
    Jul 23, 2009
    39,638
    14,830
    USA
    Here's the link. I have two of these, and both are over 20 years old...these are very durable and a good value for the money spent. Maximum weight load is 66 pounds,so its maximum load is roughly 3x the weight of the light, plus a bit more. It's always good to have some safety margin.
    Manfrotto Heavy Duty Boom and Stand - Black 085BS - B&H Photo
    Having the castors on the base keeps the light from being tipped over...it just rolls whenever somebody bumps into it or trips on the cord...always keep the cord clipped to the BOTTOM of the light stand's center column area, as close to the floor as possible...that way when (not if, but "when") somebody trips on the light cord, the pull is low to the ground,and the light stand rolls or slides sideways,and does not topple over. Use the cable clips that come with this boom stand and you're golden.
  5. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    It's standard practice to run the cable down the upright and through/under a leg so that the pull is low down.
    I suggest getting enough weights so that the weights outweigh the light and Mola. You really want the boom to be balanced when fully loaded without having the boom holder tightly clamped. This makes adjustments safe and easy.
    The boom should have a maximum load of at least 20 lbs when extended to the working distance. I like the Matthews Magic Stand which is a combo boom stand (the boom is built in). It is very versatile and sturdy.
    Best,
    Helen
  6. DeadEye
    DeadEye TPF Supporters Supporting Member
    May 16, 2007
    960
    11
    Yep as Derrel said. The Manfrotto with 15# counter weight. I have 3 of these and they never let me down. A big soft box with speedo head or speedo gridded beauty dish.
    Tip ~ get extra 15# counter weight and put it at base of stand.
  7. fadmission
    Sep 7, 2010
    Thank you everyone for your helpful information!
    @Derrel
    Does the Manfrotto's Heavy Duty Boom Stand come with weights?
  8. Derrel
    Jul 23, 2009
    39,638
    14,830
    USA
    Yes, it comes with a 15 pound counterweight, shown here. http://www.bhphotovideo.com/images/images150x150/5367.jpg
    On mine it is actually 15.5 pounds, but it looks identical...these are easily mounted to the bases of other heavy-duty stands, for added stability.
best heavy duty boom stand
