Border
Discussion in 'Beyond the Basics' started by danalec99, Jul 4, 2004.
  1. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    When I usually send a picture to snapfish for printing and/or when I try to print it at the Sony kiosk (at Kinkos), the machine tends to crop the borders.
    What should be done in PS in order to avoid this scenario?
    thanks
  2. StvShoop
    StvShoop TPF Noob!
    Jun 9, 2004
    449
    Troy, NY
    by borders, do you mean you made a frame around the picture?
    if it's that, just spraymount it to a piece of foamcore or something :p
    otherwise i dunno, probably has to be done at the kiosk or bucket
  3. malachite
    malachite Heavily Medicated For Your Protection
    Feb 23, 2004
    975
    6
    Not in Arizona anymore
    I'm guessing you mean that when you want an 8X10 or something, some of your image gets cropped to get it to fit on whatever size print you want? If that's the case, in PS, make sure your pic is exactly 8X10 inches (or whatever size you want). OR do what I do and find the option to print the entire image on the given size print you want. That will leave you unused white borders that you trim off once you get your pics back. Adorama calls it Letterbox, the software I got to use for a local lab just has a check box that says 'print entire image'.
    This is why people get into cutting their own mattes or get custom size frames made.
  4. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    When I said 'border' I did not mean the frame around the border.
    Thats what I meant. But I did try that with negative results :(
    How much does Adorama charge per pic? And can I do it from my computer??
  5. malachite
    Feb 23, 2004
    975
    6
    Yup, just upload your digi files, preview, and order. Gotta download their software of course. I just use the free version. They aren't the cheapest but are far from expensive. Quick turnaround too. S&H will kill you if you're just getting a few prints done at a time so I just copy all my scanned stuff that I want to get prints of to CD. When I get enough (10-20), I do em' all at once and pay for quick shipping.
  6. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Thanks and have a wonderful July 4th holiday :)
  7. rangefinder
    rangefinder TPF Noob!
    Jul 3, 2004
    148
    Texas
    When you put your image together in photoshop use inches THEN set the dpi. Sometimes you may need to ensure your image dpi matches the dpi on the printer. Before you burn to CD check the size (lxwxdpi) to ensure it's what you want.
    Some printers use 300, 320, 400 dpi by default. The printers are supposed to automatically compensate for this but sometimes they don't. For example a 300 dpi image on a 400 dpi printer may print out as a smaller image.
    Can you check the print resolution on the Sony Kiosk?
    I had a bunch of 4x6@300dpi files go to our local Wal-Mart and they cropped out about 1/4 all around. I think it was the technician in this case. I've not had any problems since with them or with our local Walgreens.
  8. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Good point. Thanks!
  9. Geronimo
    Geronimo TPF Noob!
    Jun 8, 2003
    1,329
    Next to the point of no return.
    I know some printers are based on the amout of pixels and not the image size. A friend spent a few hours with a few local shops to finally discover the quart.
  10. drdan
    drdan TPF Noob!
    Feb 18, 2004
    549
    Colorado Springs, CO
    You do not have to make you picture 8x10 inches, that would generally result in lowered quality printing. You only have to make the proportions the same as an 8x10. In other words one side needs to be very close to 80% the length of the other side. For instance a 2560x2048 picture has the same proportions as an 8x10 and should be able to be printed at 8x10 without cropping or losing quality by reducing the size.
    It can be a trick to get the picture you want with the correct proportions.
  11. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    drdan, I never attempted a 8x10. All I wanted was a simple 4x6 :)
  12. drdan
    drdan TPF Noob!
    Feb 18, 2004
    549
    In that case one side needs to be .666 the length of the other. so 2560x1705 should make a 4x6 without cropping. I think the bigger the picture file the more likely you are to get a good print.
walmart no border crop pixels
